Just bought a new 12bolt. Have a few Q's!!
Old 05-18-2008, 11:23 AM
Banging some gears
greyghost4x4's Avatar
Default Just bought a new 12bolt. Have a few Q's!!
Is the moser 12 really a complete bolt in set up? I had to call them back and remind them that i needed swaybar mounts. im just wonderings if there is anything else that i may need to tell them. if i can get in touch with them monday morning it shouldnt be too late seeing as how i didnt place the order til late fri afternoon. My car is completely stock suspension. You guys know of anything else that i could have missed? O yea, i also got them to give me the right coupler to make their 1350 yolk fit my stock driveshaft.
Thanks,
Daniel
Old 05-18-2008, 01:00 PM
LS1>girlfriend's Avatar
sway bar mounts and a 1310/1350 u joint along with a little cutting to make the ebrake cable mount work.
Old 05-18-2008, 08:25 PM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....html?item=146
I have a list at the link above of the parts you need. Bob
Old 05-18-2008, 10:49 PM
Banging some gears
Sway bar mounts are on there, got the 1310/1350 u joint. What kind of cutting is involved?
Old 05-18-2008, 10:51 PM
Banging some gears
so the 12 bolt is not fully assembled? axels are not installed? nor the bearings?
Old 05-19-2008, 03:08 AM
i had to cut a tab off of the ebrake mount, may not have been necessary but i thought it was.
if you bought the rear straight from moser you will have to get the axle bearing's pressed on and punch in the axle seals. most auto shops will be able to press the bearings on and if you can pick up a bearing punch kit (got mine at harbor frieght) they are very easy to install.
dont freak out over the extra work, i thought it was easy and fun.
Old 05-19-2008, 05:35 AM
EPP
EPP's Avatar
No, because you need to reuse your brake backing plates from your 10 bolt. Here are the Moser installation instructions.
http://www.exoticperformanceplus.com...html?item=1263 Bob
Old 05-19-2008, 08:22 AM
Banging some gears
Thanks!
