Need Comparison for Textralia OZ700 PLEASE HELP
I've heard nothing but good stuff for Tex single disk clutch. But I have NO clue the difference between the X & Z???? The X looks like full face on one side & sorta like a puck on the other side. Looks like a more more streetable clutch & the Z looks like a full puck style like the spec 3. I hated my spec 3 & dont want to make the same bad choice with a tex clutch.
My Car is a tuned .598 lift camed with headers & stock heads car with 150 shot TNT the spec 3 held the power But was a nigthmare to drive. The car is an 01 vert & weighs around 3600 lb with driver.
Please Help with holding power between the X & Z & drivabilty between both.
Thanks,
Scott
Thanks,
Scott
I have a x grip. It is organic on one side and has a ceramic or bronze looking material on the other. It is a little firmer than stock(not much) and holds great on a stock 99 ss. It has seen the drag strip. It is rated at 550 to 600 and the z grip(puck style) is rated for 700. I was told if I was going to put Drag radials on and spray it the z grip would be a better choice and if it is going to go to the track repeatedly. Got mine through Byun and talked to tex directly after the install. Great customer service.
