Which pusher fans should i buy for turbo setup?
Old 05-21-2008, 01:52 PM
SPRAYED 01's Avatar
Default Which pusher fans should i buy for turbo setup?
I need to put my radiator fans on the opposite side of the radiator to clear a bigger turbo and air inlet setup. I was wondering what all the FI guys are running. I also have 2 trans coolers infront of the radiator so im looking for some serious fans that can keep up with the amount of heat i need moved.
Thanks
Alex
Old 05-21-2008, 03:40 PM
RW99's Avatar
Two big SPALs, as large as will fit. Are you trying to push past the AC and your trans coolers prior to the radiator? A good shroud setup can really help...
Old 05-21-2008, 03:52 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Dunno which one I have, Speed Inc. got it for me. Works really good.
Old 05-21-2008, 04:46 PM
Monello's Avatar
I will also be needing 1 or 2 fans for my turbo setup.
Has anyone had success with keeping the AC Condensor in front of the radiator? I would like to keep it, and willing to pay for good fans that will keep the car cool.
Old 05-21-2008, 05:13 PM
SPRAYED 01's Avatar
I am tring to puch air past the trans coolers and condensor. Do you have a link to the SPALS.
Old 05-21-2008, 06:52 PM
DanZ28's Avatar
I just installed these Delale fans in my car http://www.derale.com/single-rad-fan.html. They push 2200 cfm and I have two mounted up for 4400 CFM, don't know if you can get much better than that and have them fit up.
I have two brand new Spal fans Part Number: 30102045 (1710 CFM each) http://www.spalusa.com/ that go for $150 a piece I will be selling if your interested, make you a deal .
Dan
Old 05-21-2008, 07:05 PM
Monello's Avatar
Do you think that these will be enough to flow through both the condensor and Radiator?
If so, i think i found my new fans =)
Old 05-21-2008, 07:19 PM
DanZ28's Avatar
I hooked these directly up to my battery and they push a **** load of air, but I don't know about putting the trans coolers and condensor in front of them, might be ok though. I don't see anything better out there to get more CFM threw a raidiator in a pusher fan.
Old 05-21-2008, 07:22 PM
Monello's Avatar
How much did those run you?
Old 05-21-2008, 07:38 PM
DanZ28's Avatar
Summit http://store.summitracing.com/egnsea...alse&N=700+115
Old 05-21-2008, 07:53 PM
Monello's Avatar
On the site it says
They're designed to pull air through a radiator only, not push it.
So if their mounted in front of the radiator they would be pulling it out, not pushing through right?
Old 05-22-2008, 12:06 AM
DanZ28's Avatar
Originally Posted by Monello
On the site it says
The site is wrong where you read it! In the description section right next to the part number, it reads:
Electric Fan, Single, 11.75 in. Diameter, Pusher, 2,210 cfm, Black, Plastic, Each.
I saw that to, they must have just copied and pasted it from the puller fan Derale makes. I assure you these are Pushers, I tested them myself. Also, go to Derale web site, you'll see that part number as a Pusher fan.
Old 05-22-2008, 08:40 AM
Monello's Avatar
lol, ok thanks!
At least I can mark 1 more thing off that I dont need to try and find. I will be ordering these up soon.
Old 05-22-2008, 09:20 AM
SPRAYED 01's Avatar
What cfm do you think the stockers pull?
Old 05-22-2008, 09:28 AM
Monello's Avatar
I found a thread that someone said they pulled 3700cfm total. Not 100% sure.
Old 05-22-2008, 10:07 AM
SPRAYED 01's Avatar
Im thinking of maybe leaving the pass side with the stock since i only need the extra room on the driver side. Then putting one pusher on the driver side.
Old 05-22-2008, 10:20 AM
Monello's Avatar
Thats not a bad idea. I am going to see how much room I have left once I get everything mounted. Have you thought about pushing the radiator forward a bit?
Old 05-22-2008, 10:29 AM
SPRAYED 01's Avatar
I was going to do that,but i only need a little bit of room for this setup and it seems like a lot of work. If the fan wasnt there id have plenty of room to spare.
Old 05-22-2008, 10:58 AM
RW99's Avatar
Yah, leave a puller on if at all possible. I'm also curious if anyone's ever "sandwiched" a fan between the AC condenser and the radiator... that's gotta be better than trying to push through both of them.
Old 05-22-2008, 11:02 AM
SPRAYED 01's Avatar
It would be better for cooling the radiator but the a/c probably wont work as well.
Quick Reply: Which pusher fans should i buy for turbo setup?
