315s Up Front?
Old 05-22-2008, 01:01 PM
bluebird71's Avatar
Default 315s Up Front?
I am thinking of getting a new set of front wheels with 315 wide tires up front for road corse and auto-x in my T/A. I already have 315 Nitto 555R DRs out back with 275 Firestone Wide Ovals up front. I plan to ditch the Wide Ovals for some 555RIIs with the stiffer sidewall up front. I should probably swap the 555R DRs as well, but I will probably just wait until they wear out. My question to anyone who has 315s all around is, how are the rubbing and clearance issues? Did you have to do anything special to get them to clear? What wheel offset did you use? Is it really worth it for the extra contact patch or should I just stick with another set of 275s?
Old 05-22-2008, 01:04 PM
Mr. Luos's Avatar
If I understand it correctly...we have more room to fit a 315 up front than we do in the rear.
Old 05-22-2008, 01:08 PM
bluebird71's Avatar
By we, do you mean all 4th gen. f-bodies or just T/A's?
Old 05-22-2008, 02:34 PM
Mr. Luos's Avatar
Both from what I have seen.
Old 05-22-2008, 02:46 PM
Mattism78's Avatar
I had 315's on all 4's with my old 02 SS. There is a good deal more room up front vs the rear. Way back when (when I owned the SS) there was a guy on here running 325's on all 4 corners. It looked like a steam roller
Old 05-22-2008, 03:19 PM
bluebird71's Avatar
What about the backspacing, does anyone know what is the right amount? I have the 17x9's up front so I guess I will need to trade them for some more 17x10.5's like I have in the rear.
Old 05-22-2008, 04:25 PM
Mattism78's Avatar
All 4 of mine were the same offset, so I would think you would just do the same. It's nice being able to rotate all 4 tires too.
Old 05-23-2008, 07:57 AM
venom ws7's Avatar
Search 4th or 5th page here Mangus (Not sure about the member's name) he did 315 all around.
BTW Is that PatrickG's old car looks awesome man.
Old 05-23-2008, 11:56 AM
SSNISTR's Avatar
315's are way to wide to run up front as far as looks. A friend tried it, looked horrible, like a Super Duty truck. He went back to 275's.
Old 05-23-2008, 12:24 PM
DAVE00's Avatar
Just a dumb question, but why would you want tires that large up front when you have no need for traction up there? Maybe if you were doing autoxing but still too large a tire for good control, as there is a reason that they stagger setup sports cars like the Corvette, Porsche, Ferrari etc.. from the factory for better handling in corners and acceleration with larger rear tires.
IMHO, don't do it as it will handle like crap and look the same way.
Old 05-23-2008, 12:58 PM
lt1noob's Avatar
yea its good for auto x, other than that no need.
Old 05-23-2008, 01:03 PM
dailydriver's Avatar
I guess that's why ALL of the E/Street Prepared SCCA f body
national champions (one of the few classes that are allowed to run those sizes) run that size at all four corners, right??
A straight line, drag racing setup mindset DOES NOT work for turning left and right and braking with these VERY front heavy cars.
Old 05-23-2008, 01:06 PM
DAVE00's Avatar
Agreed, but if he can't turn the wheel cause of clearance issues it doesn't matter anyway.
Old 05-23-2008, 01:25 PM
F-117HWK's Avatar
There arent the same clearance issues up front as in the back with 315's. That was pointed out above...
Old 05-23-2008, 01:28 PM
DAVE00's Avatar
But from his sig his is running lowered springs and this puts the tire in the well up front and I assume with 315's this would cause major rubbing issues when turning?
Old 05-23-2008, 01:37 PM
F-117HWK's Avatar
Its possible, but Sam's springs arent as big of a drop as most. Also I think the offest would play an important role in reducing rubbing in the front. I have seen a good number of autox guys doing it and that was what kind of application he was referring to and I would assume most of those guys are running lowering springs such as the Strano's. So can you just throw them on there, probably not. But with the right offset I would say rubbing wouldnt be as bad as you make think.
A good person to ask would probably be Sam as maybe he could tell you what size tire he is running when racing.
Old 05-23-2008, 02:23 PM
^^^^ YES!
IF he had the car 'slammed' on Sportlines or such, then yes, there might be problems.
But not on a properly set up/backspaced, etc. autocross/road race deal.
And DAVE00, SORRY if I came off like an a-hole in that response.
I just get upset when I hear bad info (as concerns handling/turning) about our rides and said handling mods.
Old 05-23-2008, 02:27 PM
SUTTERERMAN85's Avatar
i did it with 17x11 Zr1's 50mm offset and a 3/16" spacer
Old 05-23-2008, 06:04 PM
SSNISTR's Avatar
What the guy said was right, the reason the F-bodies run a fat *** tire upfront is to compensate for the lack of grip up front. A staggered setup is better. Ferrari, Porsche, Maserati the ZR1, and the ZO6 run a staggered setup for a reason!
Old 05-23-2008, 09:00 PM
99Bluz28's Avatar
So basically you need a +45 offset on the front wheels.
Quick Reply: 315s Up Front?
