hide your harness
Old 05-24-2008, 07:06 PM
markarleta1's Avatar
Default hide your harness
does any one have pics of how you hid your harness andd computers?
Old 05-25-2008, 12:14 AM
bczee's Avatar
I rerouted my wiring harness by unwraping it, moving everything around and rewrapped it. I routed the hanress to come straight backwards and into my Firewall where the ECM is mounted on top of the trans tunnel with a small console hidding it behind a few gauges and idiot lights.
Old 05-25-2008, 03:07 PM
67rsss's Avatar
Ours is very NOT hidden.
Old 05-25-2008, 06:07 PM
busta9876's Avatar
5.3 truck motor, harness re-routed, stuff for front of motor runs UNDER the intake.
You can turn the injectors around so the connector faces inward, that way the tall injector connector will lay flat against the intake, about as HID as you can get with the truck intake.
Old 05-25-2008, 07:54 PM
Thaniel's Avatar
Not sure what you mean by hidden harness but here is what my car look like. Computer is in the firewall pocket where the OEM computer was.
Old 05-26-2008, 11:59 AM
V8Rumble's Avatar
Talking
That's AWESOME, I'm gonna try that with my swap!
Old 05-26-2008, 02:44 PM
LS1 Coupe's Avatar
This is my 48 Firewall, the Main harness is just behind the drivers side head by the block going through the F/W, all my wiring, ECM and such are all up under the dash. All my other harness wire to the front end is under my d/s fender for the front lights & radiator fan. The only thing noticebly visible under the dash is the heater hoses that run between my heater box over to the p/side and then through the f/w.
Attached Thumbnails hide your harness-fw_1.jpg   hide your harness-fw_2.jpg   hide your harness-dash1.jpg   hide your harness-dash2.jpg
Old 05-28-2008, 12:08 AM
thanks guys! i can wait to post some pics
Old 05-28-2008, 11:04 PM
94Firehawk161's Avatar
Just a few words of advice. Try to hook everything up and run your swap before doing the final taping and looming/hiding of your harness. It makes it alot easier to correct any problems with your wiring.
Old 05-29-2008, 04:11 PM
Stu Cool's Avatar
Mine is not totaly hidden, but mostly where you don't notice it. The ECU is up inside the driver side front fender.
Pat
Attached Thumbnails hide your harness-fuel-rail-covers-004.jpg   hide your harness-fuel-rail-covers-002.jpg
Old 05-29-2008, 10:38 PM
68shortstep's Avatar
another one for refrence
Old 05-31-2008, 07:06 AM
68fusion's Avatar
Routed ours through the trans tunnel with the coils moved inside. Had to lengthen coil pink feed and a few grounds but the rest reached fine. Did have to lengthen the iat and maf wires since they are mounted low down near the balancer.Coils are mounted behind vintage air unit, computer mounted on trans tunnel. Wiring mess on the left is a product of weeding out what is not needed from american autowire update car harness.
Old 05-31-2008, 07:20 AM
Race your car!
JL ws-6's Avatar
Who makes that intake, and how much was it?
Old 05-31-2008, 11:22 AM
68fusion's Avatar
beck and think it was around $1800
Old 05-31-2008, 12:08 PM
Race your car!
JL ws-6's Avatar
Nice piece of hardware... very very nice
Quick Reply: hide your harness
