cam only 400whp
Old 05-26-2008, 07:56 PM
chvycmaroz28's Avatar
Default cam only 400whp
looking for what cam i could put in a ls1 6spd that would put me at or close to 400whp with headers back and a ls6 intake. i want a fairly beastly idle, but fyi..the motor has 100k on it so be carfull with telling me a cam that i will have to rev to 7krpms. unless u think the motor will handle it
Old 05-26-2008, 08:33 PM
'02 WS6's Avatar
i have a torquer 2 on 113+0 and a buddy who has a 231/237 112+2 and both did 400+.
Shift point on both are about 66-6700rpms.
Idle clip
http://www.youtube.com/watch?v=A2dDvDgXDMo
Old 05-26-2008, 09:04 PM
68birdls1's Avatar
There have been 224's that have done over 400. And don't chase a number man, that is what ricers do.
Old 05-26-2008, 11:32 PM
come on guys..looking for the biggest improvement from any speed 0-130 and doing it as cheap as possible. i have another thread where im looking for a used ls6 intake and 1 7/8 headers...also r 4.10s to much for a ls1 with just a few bolt ons? or should i hold off on the 4.10s till i get a cam?
Old 05-26-2008, 11:45 PM
rocksws6's Avatar
First off as far as the cam goes you should talk to Pred. or Patrick G. Patrick does that **** as a side job if he can't point you in the right direction nobody can. Take my advice and have him spec you a cam. You'll be glad you did.
4.10's are ideal for the M6 so everybody says ( I don't have them) but I have seen a high rate of failure in the 10 bolt with 4.10's. The pinion is really small to get that ratio thus making it weak. I'm going with 3.73's and when I get a aftermarket rear end I will probably run 4.10's or 4.30's. If your not going to do any drag racing I would say 4.10's if you are I would say stick with what you got or run 3.73's.
FYI 230/232 110+2 = 397 whp and 377 trq.
Edit I think my thread with the dyno sheet got deleted or something I can't find it anymore.
Old 05-26-2008, 11:49 PM
I will post up a link to the thread with my dyno sheet in case you want to look at it.
with 2 degees of timing? do u think 400 could of been reached with 1-2 for degrees?
Old 05-26-2008, 11:53 PM
rocksws6's Avatar
I'm guessing you mean 1-2 more degrees. Usually when you advance the cam you give up peak for under the curve. If you advanced it more it would make more bottom and less top.
Chris1313 has a 230/230 111+2 and he made 422 whp through an auto. Its hard to shoot for a # because you really don't know what your going to get. I would stay low 230's nice mix of street manners and power.
Old 05-27-2008, 12:01 AM
FMS Custom Grind Camshaft - 230"/232" .595"/.585" 112LSA????
my main concern in spinning a 100k mile motor to almost 7k
Old 05-27-2008, 12:29 AM
Kingc8r's Avatar
LS1Tech 10 Year
I wouldn't put any money into a 10 bolt....I'd atleast get a 12 bolt and definatley a 9 inch for M6s...4.10/11s wake M6s up...
Also as to the OP, take rocks advice and have Pat G or Preditor spec you a cam to work best with your current combo
Old 05-27-2008, 12:36 AM
rocksws6's Avatar
My car made 390+ from 6k to 6.5k it didn't fall of much from there to redline. I don't think you have much to worry about with having 100k miles. I've got 85k and a bunch of guy's on here are well over 100k still running strong as ever. I have the limiter set at 6750 but I hardly ever rev it that high. I usually shift around 6500. You can't be afraid of hurting it though. That takes all the fun out of it. Give it hell. If it breaks get a used shortblock for next to nothing or up the ante and go forged and your ready to go again.
That FMS cam would probably work. I went back and forth on cams so many times I figured I would let somebody else decide for me. Told Pat. what I had and what I wanted and he hooked it up.
Old 05-27-2008, 12:39 AM
i hear his name alot...can u or someon hook me up with him....whats his name on here
Old 05-27-2008, 12:41 AM
95 Z28's Avatar
Any mid 23x/23x cam should get you there, or very close. My 232/234 did 395 SAE with n2o plugs and heavy wheels. The first time out it was trapping 115 launching off idle, so don't get too caught up in what it'll put down on the dyno. Going custom with either PatrickG or Predator is an excellent idea.
Old 05-27-2008, 12:42 AM
rocksws6's Avatar
I'm doing my own install and bought gears for $50 so for about $200 I will have some gears in it. I'm going to beat it till it breaks. Then I will go aftermarket. I can't let the ol 10 bolt off that easy. Its gotta die before it retires. That and it makes it easier with the woman.
You want to fix something that ain't broke? I don't think so.
Oh so you have to buy a new rear end so you can get to work? Ok.
Old 05-27-2008, 12:45 AM
rocksws6's Avatar
Here ya go:
https://ls1tech.com/forums/member.php?u=210
You can see in his sig where to click for his cam website.
Good luck.
Old 05-27-2008, 12:51 AM
i can learn alot from u
Old 05-27-2008, 06:49 AM
PONTIAC SLP's Avatar
i made 408RWHP with MS4 112LSA , hokker headers longtubes , slp cat-back LM and 4.10
idle http://www.youtube.com/watch?v=TKo_kVT92u8
Old 05-27-2008, 10:33 PM
'02SOMz28's Avatar
i have a 231/237 112 it did 404/394
Old 05-28-2008, 12:04 AM
what else is needed if i bought a ms4? springs? rockers? pushrods? bigger fuel pump? etc
Old 05-28-2008, 03:15 AM
smokinponcho73's Avatar
im pretty sure to go with the ms4 all you need is .660" springs and maybe pushrods. and i wouldnt go with 4.10s on your 10 bolt with 100k and an m6 that has a lot of wear as it is then you put the leverage of the 4.10s and something is gonna give. I say give her hell till she screams mercy, then fix her and do it again.
