Put New Motor in...Can anyone tell me where this goes?
Old 05-27-2008, 12:52 AM
HottLS1Z's Avatar
Default Put New Motor in...Can anyone tell me where this goes?
The connector and the ground strap. Both come from the harness that runs alongside the drivers side of the car. Other end of the ground strap os bolted to the frame ant goes into the harness then back out and is hanging there, I dibt remember seeing it before. The harness I dont remember taking off and neither does my friend who is helping on the motor swap. Can anyone tell me where they go or what there for? All ready to fire it up just didnt want to until I figure out where they go
Old 05-27-2008, 01:07 AM
Ericbigmac83's Avatar
ground goes to the alt.
not sure on the connector. what other connectors are on that harness? remember that they are usually cut to length, so it should stop fairly close to where it should go.
Old 05-27-2008, 01:20 AM
HottLS1Z's Avatar
Thats what I thought but cant find anywhere that it fits to bolt upto and my buddies 98 dont have it on there, unless I over looked something...
Old 05-27-2008, 01:42 AM
COOKIE MONSTER's Avatar
Whats it connected to?
Old 05-27-2008, 01:52 AM
HottLS1Z's Avatar
Like I posted above there both coming from the hanress, the other end of the ground strap is grounded to the frame.
Old 05-27-2008, 08:07 AM
andrew69_04's Avatar
if i remember right, that looks like your plugin for your Cruis control module. it sits underneath the frame rail where the connector is hanging. That ground strap is supposed to go between the frame and the block.
Old 05-27-2008, 08:11 AM
rpmauto's Avatar
yes, that looks like the plug in for the cruise control, the ground strap bolts to the drivers side upper frame rail, along with another ground, and then bolts to the block behind the alternator, just had mine out.
Old 05-27-2008, 08:14 AM
Frans96SS's Avatar
Ground goes to the block and the connector looks like its cruise control...
Old 05-27-2008, 10:13 AM
HottLS1Z's Avatar
Thanks for the help guys I dont have cruise that explains why I dont recall unplugging it and cant find where to plug it in huh lol Well where on the block does the strap go? Didnt look like the bolt for the alt would fit it but I will pull it apart and check again if thats where it goes...
Old 05-27-2008, 12:41 PM
Frans96SS's Avatar
there is alittle spot on the side of the block where that goes... its a short 15mm bolt i beleive that holds it in. Might be 13mm i forget off hand.
Old 05-27-2008, 12:59 PM
HottLS1Z's Avatar
So is the strap for grounding the alt or the engine? Looks like it can bolt to 2 places either the bracket behind the alt or between the bracket and the block..
Old 05-27-2008, 01:21 PM
Frans96SS's Avatar
it bolts to the block
Old 05-27-2008, 03:43 PM
HottLS1Z's Avatar
straped it down by the bracket and the block and not getting a charge, gonna take and have it tested even though its a new alt, maybe its defective or sometihng
