Question about Rasp?
Old 05-28-2008, 03:15 PM
Medic1's Avatar
Default Question about Rasp?
I have a 2002 Trans am WS6 with SLP LT's with cats and loud mouth exhaust, and there is some rasp, what actually causes the rasp? Soon I will be getting stage 2 heads and cam with kooks LT's and cats with that setup is there still going to be some rasp??
Thanks
Old 05-28-2008, 03:20 PM
LS1-NAVY's Avatar
yes but alot less because the cats thats y i got a catted y-pipe because i hate rasp
Old 05-28-2008, 03:27 PM
Dragkid1917's Avatar
its the resonator in the loudmouth. it opens up to 4 inches and makes rasp. I have the same problem, im getting a borla xr1 racing muffler to combat the issue.
Old 05-28-2008, 03:38 PM
LS184's Avatar
just swap out the slp resonator
Old 05-28-2008, 04:11 PM
Medic1's Avatar
with the setup that I mentioned before on what im getting the heads and cam and kooks, if I get a true dual setup would the sound be louder? would you guys recommend that setup?
Old 05-28-2008, 04:19 PM
LS184's Avatar
depends on wht muffler setup u choose with the true duals
Old 05-28-2008, 04:22 PM
King Nothing's Avatar
the resonator is giving you the rasp, question: what exhaust are you running to the resonator? a y-pipe or TD's? i had a H crossover put in my TD set-up with my LM1 resonators and it quieted down the rasp
Old 05-28-2008, 04:23 PM
hlaalu's Avatar
real men use borla!
Old 05-28-2008, 04:24 PM
LS184's Avatar
hes running slp longtubes with cats
Old 05-28-2008, 05:03 PM
Medic1's Avatar
I have the y-pipe going into the resonator, and if I go with the TD im thinking of going with 2 resonators both LM1
Old 05-31-2008, 03:19 AM
RoDan's Avatar
ok, talk about an annoying word! whoever coined the term "rasp" I'm gonna kick their ***...
Old 05-31-2008, 11:42 AM
02silvaZ's Avatar
its raspy cause you have a resonator and not a muffler, LM's are raspy *****
Old 05-31-2008, 01:31 PM
z28bryan's Avatar
It's the loudmouth. If you swapped to a Magnaflow, I guarantee it would go away.
Old 06-01-2008, 10:36 AM
Medic1's Avatar
If I swapped to a magnaflow would it still be loud as the lm1 just without the rasp??
Old 06-01-2008, 01:35 PM
LS184's Avatar
no it will b alot quiter...but it will sound much better
Old 06-01-2008, 04:36 PM
2000ssowner's Avatar
i second that.
Old 06-01-2008, 09:53 PM
Full-Force's Avatar
guys, the freaking resonator is not causing the rasp
