what is this hose for
i have an 02 camaro and there is a hose on the right front on the intake that goes down the side and around the back of the intake and looks like it goes down the l/s fender. the fitting and valve is cracked and i just want to know what it is so i can replace it.
You need to post pics or something.
What size is the hose? what material, hard plastic, rubber?
Right side as looking at it or sitting in the vehicle?
Without a picture you're going to get a bunch of misleading guesses, unless you can be way more specific.
it is on the r/s if you are sitting in the car i think it is the pcv valve. it a fat rubber hose the goes into a small hard plaste hose that is covered in foam. it also has a gound strap on it. that fat rubber hose is cracked, is this some that auto zone would stock or is this a dealer item. also would this cause a vacuum leak?
Mine is cracked too! Right where the Ground Strap is, its ripped in half almost.. I believe i am getting a vacuum leak from it also.
Its the hose that holds half of the PCV valve.
+1 someone help us
+1 someone help us
Dealer only on that, I hear the price is very high though.
There are different ways to duplicate the pcv system with regular fuel line and a different pcv valve. For 1/3 the cost of the dealer stuff.
Anyone know what size line or what valve? Could I cut off that big piece and just slide another big piece over the hose in its place?
