what is wrong with my m6 ? vid inside
Old 05-29-2008, 05:00 PM
Mohammed's Avatar
Exclamation what is wrong with my m6 ? vid inside
notchy feeling...all gears are ok except for the 4th... sometimes it goes fine,but sometimes I have to put in neutral and engage it again ... see vid..Does the shifter make this problem or something else...I hope it is the shifter !!
http://www.youtube.com/watch?v=6kQJ8hP-U6A
Old 05-29-2008, 05:38 PM
ae13291's Avatar
link no worky for me! if im not mistaken, if u have to double clutch it sounds as if its ur syncros. try changing the tranny fluid too that can help!
Old 05-29-2008, 08:31 PM
wrencher
wrencher's Avatar
That is most likely internal trans problems. The 3/4 fork, shift fork pads syncro's etc.
The trans will need to be tore down inspected
Old 05-29-2008, 11:47 PM
ChicagoTransAm's Avatar
Ditto... 3-4 shift fork or syncros
Old 05-30-2008, 12:48 AM
Mohammed's Avatar
I don't know about this..but is it a big problem that costs a lot of money !!!?
Old 05-30-2008, 01:45 AM
jinusow's Avatar
syncros. Get it done while fixing is cheap(er). If you run it like that and ruin 4th gear it is the most expensive gear to replace plus 3rd could end up damaged too even if you don't hear or feel it like you do in 4th gear. Not that I've ever f'd up a gear or two in my day
Old 05-30-2008, 05:15 AM
Mohammed's Avatar
how to fix syncros ? anything to be replaced ? or what ?
Old 05-30-2008, 08:03 PM
zdc590's Avatar
Synchros are inside the transmission itself. In REALLY basic terms they are what makes shifting easy. If it is indeed a synchro you'll have to drop the tranny and get inside there to fix it.
