LSA vs. horsepower
LSA vs. horsepower
what does lsa do to the horsepower. from what i understand a tighter lsa will produce more horsepower. but i have also heard people say that they are going with 112 vs. 114 to keep the rpm's down. is this true too? that the tighter the lsa the quicker it will peak.
thanks for the info
thanks for the info
Re: LSA vs. horsepower
What I have always heard from the cam companies is LSA has nothing to do with the peak horespower. It will just change the shape of the curve; a smaller LSA will make the powerband start later and end earlier, with the peak about 200 rpm lower for a 112 vs. a 114 LSA. In other words, the engine will be more "peaky," as well as hit it's peak sooner. IMO this makes the car more fun to drive, but it is also less predicable with a rougher idle, and harder to pass emissions. It's just all what you're looking for, but the same power either way.
Cal
Well said!
I noticed with wide LSA cams, the power doesn't drop off as quickly past the rev range as a tight LSA cam does. I do enjoy the BOOMing midrange pull of a tight LSA cam as it enters the power band.
Well said!
Cal
Well said!
Well said!
My understanding has always been that with all else equal (lift, duration, intake centerline) a smaller LSA will increase peak horsepower and move the peak toward higher revs. A smaller LSA increases overlap which improves exhaust scavenging at higher revs thus increasing peak power. Cal says, “a smaller LSA will make the powerband start later and end earlier” without increasing peak power. It seems to me that if that were true, the area under the power curve would be reduced and there would be no benefit. Where am I wrong?
TT-TECH Veteran
Do not take my word for it but the guy at COMP CAMS ( I was on the phone with him for an hour) told me that the LSA would determine the power band like 1500-5500 rpms and the ICL would determine when it would come on. for every 2 degrees he said that you bring the power on around 200rpms sooner but he said that was just rule of thumb not exact. so now you are going from 1300-5300 rpm in your primary power range. That is what I got out of our conversation but just thought I'd throw that in there for thought I am not a cam guru though. I was in question my self so I called a cam co. thought it was the best source for information. Good luck with it!
