Water in the gas tank?????
Old 05-31-2008, 09:09 PM
LS1Z28-00's Avatar
Default Water in the gas tank?????
my car was on empty so i went to one of the local arab gas stations to get some gas. i put in 10$ of gas which is what 2 gallons of gas. anyway after about 100 yards of pulling out of the station the car started missing and idleing VERY ruff. RPMs went down to like 2-300 rpm and i made it maybe 300 more yards and it died. so i went to the store and bough a can of dry gas and put in another gallon of GOOD gas and now it will start up and idle for maybe 10-15 secs and run really ruff and die. ive tried to start it for like and hour, nothing. do you guys have any suggestions on this.oh yea i recently installed a walboro 255lph fuel pump. however ive been driving the car for 3 days with no problems until now. the pump comes on and sounds strong. any suggestions? i dont believe its a pump issue b/c ive prob driven 30 miles on it with no issues and i happend all at once after putting gas in.
Old 06-01-2008, 01:29 AM
CULATR's Avatar
pm sent!
Old 06-01-2008, 01:32 AM
TransFan's Avatar
That sounds like the story of my pump. Car was running fine as I pulled in a gas station. After topping her off she would start, idle rough and then died. FUEL PUMP was gone. 800 dollars later I was driving again.
Old 06-01-2008, 01:33 AM
TransFan's Avatar
You could try changing your fuel filter.
Old 06-01-2008, 07:33 AM
LS1Z28-00's Avatar
i surely hope not, i just put in that wally 255lph. i was giving it hell prior to getting gas? the pump still comes on and seems to be pumping strong from the sound of it. guess i need to check the fuel pressure eh and go from there if i cant get it started.
Old 06-01-2008, 12:58 PM
2002_Z28_Six_Speed's Avatar
If it is truly water in the tank then some alcohol additive should clear that up for you.
Old 06-01-2008, 07:42 PM
LS1Z28-00's Avatar
yea i added a whole can to like 3 gallons of gas. i guess it has to be the pump. i tried to start it today and it wouldnt run for even 2-3 secs.
Old 06-01-2008, 07:50 PM
TransFan's Avatar
Hope it isn't your pump though. I guess it's luck that when you have a problem with a car it is usually the most expensive part that goes bad. Good luck.
