CME Camaro guys...what do you think???
Old 06-03-2008, 01:53 PM
kidcamaro98's Avatar
Default CME Camaro guys...what do you think???
I just put my Hooker longtubes on and my Pace setter off road Y pipe...my car is a SLP SS so it came with the SLP Center mount exhaust....I kept that when I did my header install...
My buddy has a WS6 with just a flow master Muffler, and its just as loud as mine with the headers. What Im wondering is, Can I change out the SLP muffler and still use the SLP CME tips?? I want a less restrictive, more aggressive muffler.
I had Magnaflow on my turbo V6 and it was loud...but is it any different then the SLP one??
Old 06-03-2008, 01:55 PM
7camaro7's Avatar
yea you can, I did check my fquick. hit the red camaro in the upper left then watch the video on the right
Old 06-03-2008, 02:00 PM
94'BLKBRD's Avatar
yes it can be done, some people have used the GMMG exhaust
Old 06-03-2008, 04:39 PM
Black Sunshine/ 00SS's Avatar
Just change the tips, the stock ones suck, compared to the aftermarket ones I've seen
Old 06-03-2008, 07:29 PM
Not changing the tips...my car is a SLP SS so im not taking the SLP factor away from it.
Old 06-03-2008, 09:20 PM
MasterEvilAce's Avatar
WHAT?
No way. Stock CME > all
Old 06-03-2008, 11:03 PM
LS184's Avatar
ive seen people run 2 bullet mufflers in place of the stock muffler, or evn 2 loudmouth resonators in there, tht should wake it up alot
Old 06-03-2008, 11:07 PM
LS184's Avatar
and slp does sell different tips for the cme, they have these on clearence http://www.slponline.com/view_product.asp?P=302500001
Old 06-04-2008, 05:59 AM
vatechguy3's Avatar
the quad exhaust tips use a different valance than the standard cme tips.
tony
Old 06-04-2008, 09:44 AM
SupermanSS's Avatar
What exactly makes a SS a "SLP SS" my car came with the 345HP CME Exhaust package and other SLP goodies, does that mean its a "SLP SS". I thought every SS made had to undergo the transformation process from SLP so in essence aren't all the SS breed SLPs?
Old 06-04-2008, 11:54 AM
ssgunny's Avatar
You are correct. I guess if you go out and buy more of thier stuff and put it on that would make it more special. lol
I say keep the setup you have and put a dump/ecutout in the I pipe.
Old 06-04-2008, 01:00 PM
Pesticide's Avatar
I have a similar setup. I just kept the stock muffler and CME tips, but installed a electric cutout in the I pipe.
Old 06-04-2008, 01:33 PM
Sommer86's Avatar
You're right, all SS's went through SLP...but some got the "second sticker" options that other didn't. My car is an SS, but doesn't have a second sticker on the passenger door. The passenger door would have a label with all the EXTRA SLP goodies that make it an SLP upgraded model.
Old 06-04-2008, 01:37 PM
andrew69_04's Avatar
changing out the muffler wouldn't be hard. my buddy had pacesetter lt's and ory with the cme and a cam and it sounded really good. imo i would leave it, if you want sound, just install a cutout
Old 06-04-2008, 01:50 PM
02silvaZ's Avatar
that muffler is the same as the dual/dual muffler, so it flows pretty damn good, i would drive it around a little while before you do anything drastic, alot of people want loud only to find out they wish it was quieter
Old 06-04-2008, 04:15 PM
SupermanSS's Avatar
Yeah mine has the sticker. But I don't call it an SLP SS , I hate that,no offense to OP though.
Old 06-04-2008, 04:20 PM
Yah, my SS has 2 SLP stickers...one on the drive side door, and the other on the passenger with all the info that SLP did...
Old 06-04-2008, 10:47 PM
Then keep it original. Dont change a thing. I'm a fan of the CME, mine did not come with one, and though it's a SLP SS, There really isn't much on it that is stock, let alone SLP. LOL.
I just dont like the as cast CME tips, because they get dirty, and look like ****, unless you polish out the casting, and or switch to the tips sold on EBAY, and a few other places, which are the same style, just smoother & I think a little bigger. JMO
Old 06-13-2008, 12:34 AM
lilbuddy1587's Avatar
Check to see if you have a cone/ring of silence on that muffler. Very possible that it could be your culprit as to why the car is so much quieter.
https://ls1tech.com/forums/showthrea...t=silence+cone
If so, remove it and go from there. I think if it is infact your problem, you'll be more than pleased with the sound when taken care of.
