best amp 3 subs
heres the info on the subs:
# 10" W3V2 Series Subwoofer
# RMS Power Handling: 300 Watts
# Dual 4 Ohm Configuration
# 2-1/4", 4-Layer Voice Coil
# Kapton Voice Coil Former
# VRC Technology: Cools the Voice Coil
# Elevated Frame Technology: Enhanced Cooling
# Powder-Coated Silver Frame Finish
# Dished Cone/Dust-Cap Design
# Rubber Mounting Flange Gasket
# Sealed Box Volume: 0.60 - 0.90 cu. ft.
# Ported Box Volume: 1.0 - 1.5 cu. ft.
# Top Mount Depth: 5-3/4"
# Cutout Diameter: 9-1/8"
i am trying to keep my entire system jl. i have never had any problems with any of there stuff. goin with 3 guess cause i want it to be really loud
If you have 3 dvc 4 ohm subs, you can wire them all in parallel for a total load of .67ohms. You just have to make sure your amp can handle that, which I don't think JL makes one that will. If you wire the two coils of each sub in series and the subs in parallel, then you'll have a total 2.67ohm load. The JL amp will handle that, but you just need a like 900W RMS to at that load. A JL 1000/1v2 would probably do well, but you're talking about a 650-1000 dollar amp, depending on where you buy it. If you only go with 2 subs, you can use a 500/1v2 amp and save about 300 bucks on the amp itself.
For the 3 jl subs with 2.67 ohm resistance a Hifonics BXi 1608D will probably give you around 800w rms, for $300 online.
Or if you want a little more power a Hifonics BXi 2008D with around 1000w rms ,with the 2.67 ohm resistance, for $340 online.
FYI, if you ran 2 or 4 subs your amp choice would be alot better!
actually 2-12 w6 are perfect and give u this great low deep bass 3 10s are nice but if you dont want 2 spend that much money just get 2 10 w6 they will sound better than 4 10 w3 but definetly go with a 1000-1 u can never go wrong with that amp and you wont have to mess with ur alternator
Better then A JL Amp !
I M O, MMATS D2000.2 with a 2.67 ohm load should give you a good 1000 watts, and a easy load for this amp. And when you decide to add a 4th sub you'll get the full 1500 watts, and also this is a underrated amp.
Small, efficient, and kick-***! And it's on sale right now for $570 online, of course.
And no...lol, I don't work for or sell MMATS amp....lol
You should go with a ZAPCO. By far some of the best car audio equipment available. I have three Reference amps two 500.1 and one 360.4. JL audio is good but Zapco is better. JL is, IMO a little less than the reference amps produced by Zapco and cannot hold a candle to the competition amps Zapco makes. Take a look you will not be disappointed.
Actually a Zapco REF1100.1 would be perfect his subs would get around 1000w rms with a 2.67ohm load, and he could get one online for $770
US Amps, and Sundown Audio also make some really good, but expensive amps, IMO.
I'd go with like a Hifonics BX11608D. They're not the best amps in the world but they are plenty good, especially for a subwoofer (where SNR doesn't matter as much)
