Rapid Heads - Mild Cam - 12 Bolt = 430rwhp
Old 08-13-2003, 04:28 PM
LS1TECH Sponsor
mikey's Avatar
Default Rapid Heads - Mild Cam - 12 Bolt = 430rwhp
The car is a 2002 Trans-am (collector edition). Mods are Rapid Stage II LS1 Heads, 224/230/114 XE-R cam (mild by today's standards), FLP headers through the cats, Magnaflow exhaust, SLP 85mm MAF, SLP Lid, Moser 12 Bolt with 4.11 Gears. No UD pulley, no ported TB, no ported intake, no cutout. Tune was 12.8:1 flat, timing at 29 degrees. Heads were not cut for compression, just an .005" clean-up.
Old 08-13-2003, 04:56 PM
01 SS Jay's Avatar
Default Re: Rapid Heads and Mild Cam = 430rwhp
Damn nice!
Old 08-13-2003, 05:04 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
That's an impressive graph!
Old 08-13-2003, 06:51 PM
LEO
LEO's Avatar
That's a pretty good increase over your ARE heads/cam combo - 16 rwhp.
Old 08-13-2003, 06:56 PM
Shorty Director
VINCE's Avatar
That is awesome. Your dyno looks almost identical to my dyno graph except I have a bigger cam and Stage I's and you have 9rwhp peak.. Congrats on the #'s.
Old 08-13-2003, 07:05 PM
7 Second Club
Phil99vette's Avatar
Very interesting....GREAT RESULTS!. Do you know your the flow #s on your heads? If you have them please post them so we can see i/e efficiency because its clear your flow likes a split duration.
Phillip
Old 08-13-2003, 10:48 PM
I have to admit I'd like to see that set up with an underdrive pulley, ported TB & a cutout. Might be ~450rwhp?
Old 08-14-2003, 07:29 AM
ne14a6t9's Avatar
are those gtp heads,lookingat your web site the only heads I see are gtp's. the torque is kinda on the low side, is there a cam that would bring that up and you can see how much more efficient the 02 cars are with the way the motor peaks, wish mine was an 02
Old 08-14-2003, 08:05 AM
ScreaminSS01's Avatar
Wow I did nto expect to see that much peak hp. Looks good Mikey.I am sure he will be happy with the combo.He told me that he was excited about the package.
Old 08-14-2003, 08:29 AM
ezss's Avatar
Looks good! Get him the rest of the bolt-ons and he is really cruising.
On a side note --
I dont really get that split on the cam...why all the exhaust duration? Seems like that would just bleed off torque without giving a significant increase in HP, unless he is going nitrous later on. I guess this is why Im not putting together H/C packages!
Old 08-15-2003, 10:17 AM
SMOKINV8's Avatar
While it looks like a nitrous cam, it also seems like an aweful lot of people are making very impressive N/A numbers with traditional split cams. GM spent their millions on R&D, and came up with traditional splits for their cams. Lingenfelter uses traditional split. LG's G5X2 cam uses a traditional split. If I remember right, I think Joe Prince's new cam uses a traditional split as well. I'm not sure why, but something definitely seems to be working together on the car's that they all advertise the most.
I would also be very interested in seeing those flow numbers!
Old 08-15-2003, 10:31 AM
Ragtop 99's Avatar
Nice work, Mikey.
Old 08-15-2003, 10:58 AM
Super Moderator
Reckless's Avatar
Nice job Mikey! Very nice numbers for sure!
Old 08-15-2003, 02:28 PM
oOoLy's Avatar
WoW...........Looks sweet awesome numbers
Old 08-15-2003, 03:48 PM
CHRISPY's Avatar
Nice numbers!
Smart idea with that exhaust duration to compensate for the added backpressure of the cats!
Old 08-15-2003, 10:26 PM
98TAauto's Avatar
awesome MIKEY!!! nice numbers from a mild setup!
