STRANGE front shock, do you run the shield/jounce bumper????
Old 06-08-2008, 10:19 PM
studderin's Avatar
Default STRANGE front shock, do you run the shield/jounce bumper????
Dose this get reused? It limits the amount of shock travel a bunch. I'm using the stock front coils btw.
thanks
Old 06-09-2008, 09:21 PM
99Bluz28's Avatar
If you're using the factory upper a-arm you can mount a bumpstop up above the balljoint; first, just pop the upper balljoint out of the spindle then swing the a-arm up until you can see where you need to drill a hole to mount your poly. bumpstop, I think there's a small hole already there, not 100% sure.
Quick Reply: STRANGE front shock, do you run the shield/jounce bumper????
