Squealing brakes
Now, I know pretty much all there is to know about brakes so this is really pissing me off. What I really need to know is every possible point of contact that could cause high pitch squealing Thanks in advance.
Bought a 2000 Z28 7 months ago and they were squealing, so I have replaced all 4 rotors and put on all new ceramic pads to no avail.
I have had about 10 cars and have never had this be a non-stop issue in the past.
Is this squealing/whistling indemic to camaros????
If the brakes are new and installed properly, the hubs/bearings may be going out. As they wear out, they can create a squeal that sounds like a break squeal.
my f150 that i drove had squeaky breaks from like 0-35mph and it never went away even after everything was changed. brakes worked fine so i really didnt care.
The rear pads looked to have some life left(they were at 50% with 55k miles), but I bought some new pads and had the rear rotors turned.
I replaced both the front and rear pads with the most expensive thing O'Riely's had, and I replaced the front rotors with new GM OEM spec units at 55k. At 115k, my brakes are still great.
My point is that you should buy the best parts you can. I did that and my brakes are still fine after 60k miles.
