motor mount torque
motor mount torque
I did some searching and I found JRP's torque spec FAQ but Im not totally clear on what part is what. I need the individual torque specs for all the below
stock cast lower motor mounts 4 bolts to the stock k-member
stock upper motor mounts to the aluminum block
long through bolt & nut that joins the two
