engine temp out of whack
Old 06-10-2008, 04:17 PM
c5z28's Avatar
Default engine temp out of whack
I have a 00 z28 (stock) and on long drives on the freeway usually an hour or so the temp goes whacko. It will go from like 209 to 230 in a seconds time and then go back down to the normal temp, it will do this within a few seconds of the last, and yesterday the temp went up to 260 in like 1 second then went back down to op temp, I even ran it with a/c, with heater full blast and just off no difference, I took it in to the chevy dealer and they said no thrown codes or ****, now I am out 100 bucks for them to tell me they dont ******* know?! I am taking it to infineon tomorrow, it did the same thing one time before I got to the track then it was fine. Can someone help?
Old 06-10-2008, 04:20 PM
krayzie7th's Avatar
probably could be a faulty ECT sensor that control the gauge.
Old 06-22-2008, 08:25 PM
mrburnout81's Avatar
Did you have any luck figuring out what is going on? My car is doing the same thing. it will be perfectly fine, running at 210, then all of a sudden it pegs the gauge, then comes right back down. will do it if i am sitting at a light or driving down the interstate. have changed the thermostat and coolent temp sensor and it seemed to help for a few weeks then it started up again. when it pegs the temp gauge i have looked under the hood, and nothing seems out of the ordinary, no steam or anything. still runs like a raped ape. just aggravating
Old 06-22-2008, 09:35 PM
needadvice's Avatar
put a new temp sensor in. Coolant can't rise and fall in 30-50 degrees in a matter of seconds, it takes minutes.
Old 06-22-2008, 09:37 PM
needadvice's Avatar
Thats because there is nothing going on, the temp sensor needs to be replaced.
http://www.rockauto.com/catalog/x,ca...,parttype,2188
Old 06-23-2008, 10:17 AM
Have already replaced the temp sensor. unless they need replaced every month
Old 06-23-2008, 10:53 AM
needadvice's Avatar
Then the wiring must be shorted somewhere along the line, or frayed. Or the guage cluster is messed up and the signal is getting screwed up.
Old 07-11-2008, 06:10 PM
RavensHawk's Avatar
I'm having the same issue. Any luck fixing yours yet??
Old 07-12-2008, 06:08 AM
Weezzer's Avatar
... it will be perfectly fine, running at 210, then all of a sudden it pegs the gauge, then comes right back down. will do it if i am sitting at a light or driving down the interstate. ...
Excluding the '98 year, all the gauges display a temperature reading of 210 degrees when the actual coolant temperature is between 180 to 226 degrees, once it rises above 226 the gauge will show the actual reading - making the temperature appear to rise and fall by a large margine in a matter of seconds.
Old 07-12-2008, 10:21 PM
lt1noob's Avatar
same here, but mine actually did over heat to the point that it was shaking violently.
Old 10-17-2008, 09:06 PM
c5z28's Avatar
Sorry I don't get seem to get updates from this website, turns out it was a sticking thermostat.
