undecided between ls7 clutch or ram????
Old 06-11-2008, 12:34 AM
LS1PHNX's Avatar
Default undecided between ls7 clutch or ram????
My car makes about 400rwhp....i dont do a lot of racing...i mainly just drive to work and back and i cruise it on weekends. I installed an ls7 clutch on a buddys car and it feels great. however, i have also heard a lot of good things about ram clutches...i cant make up my mind...what do you guys think?
Old 06-11-2008, 01:31 AM
1sick'98WS6's Avatar
ls7 would be sufficient for 400rwhp and if it is a DD you cant beat the pedal feel and longevity it will yield you in comparison to an after market clutch. Ran my LS7 clutch for 40 thousand miles just DD and Sometimes racing, I put down 411rwhp.
Old 06-11-2008, 04:01 AM
02Z28LS1's Avatar
i think that the 505HP Z06 Corvettes come with an LS7 clutch, and they seem to hold stock power ok, so it should be more than enough for a 400HP f-body, even with the extra weight that the f-body has over the Vette....and it's a nice, cheap setup, too.
Old 06-11-2008, 07:17 PM
LS1PHNX's Avatar
i have an ls6 z06 clutch in my car right now and its hung in there for over 25000 miles....so im sure the ls7 clutch would be even better...also another question...should i stick with the ls2 flywheel (thats included in the kit) or i should i run an aluminum flywheel? would it make a difference?
Old 06-11-2008, 07:49 PM
camaroride32's Avatar
just got finished a couple hrs ago installing an ls7 clutch kit in my 00 ws6 from the factory ls1. All I can say is WOW!!!! What a difference that clutch made. I cant wait for the 600 mile break in so i can really test it out!!!
Old 06-11-2008, 08:18 PM
LS1PHNX's Avatar
are you using the ls2 flywheel?
Old 06-11-2008, 09:55 PM
Omec's Avatar
you have to w/ the ls7 clutch.
Old 06-11-2008, 10:25 PM
LS1PHNX's Avatar
are there any other good flywheels to use with that clutch?
Old 06-11-2008, 10:53 PM
tavi_ws6's Avatar
ive havent drove a car with a ram clutch but i love my ls7 clutch, good pedal feel and good price
Old 06-12-2008, 04:55 PM
SIC LSX's Avatar
LS7 with ls2 flywheel all the way! I hate the chatter from the ram. I have 413whp and i have cut 1.6 60ft with my ls7 clutch and it has 25,000 miles on and still barks 4th gear. Nice smooth pedal and no charter just like stock.
Old 06-12-2008, 07:45 PM
88zukon36s's Avatar
As long as your are not running drag radials or slicks at the track you should be ok. I am replacing my ls7 this week end. It has maby 6000 miles and 6 passes at the track. It is slipping bad on hard launches and i am arount 435 rwhp......
Old 06-13-2008, 07:13 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Go with the LS7
I ran it when my CETA was a 6 spd and the car put down over 600 rwhp on spray. Never had a single problem at the track and DD the car
