Help, I need a lift!
Old 06-13-2008, 10:24 AM
captainwizbang's Avatar
Question Help, I need a lift!
Ok, here's the story. My car has a lowering kit on it that drops it an inch or so. Couple of weeks ago I broke my torque arm and snapped my drive shaft at the track. I replaced the saft and installed a BMR torque arm with a cross member so I would not have to reconnect the torque arm to the transmission. The cross member has a dip in it to provide clearance for the exhaust. I now have about 2 inches of clearance under my car.
I'd like to keep my ride height for the drag strip but be able to raise my car a couple of inches for daily driving. Any recommendations?
Old 06-13-2008, 11:35 AM
UMI Performance's Avatar
Do you have the short torque arm that welds into the SFC's or a torque arm with torque arm relocation kit?
Old 06-13-2008, 11:53 AM
The SFC weld kit. BMR TRAK PAK
Old 06-14-2008, 05:11 PM
bump
Old 06-14-2008, 09:18 PM
Sinister95Z's Avatar
Keeping it low at the track is not the best for wieght transfer and all around suspension articulation. It sounds like a set of stock springs or a set of adjustable QA1's would suite you better than your current springs.
Old 06-15-2008, 09:43 AM
Ya, I see your point. I was considering something adjustable like and air assisted suspension. I'm hoping that will allow me to have the profile I want but adjust my hight as needed.
Old 06-15-2008, 08:48 PM
Anyone here ever try Air Ride Technology's products?
Old 06-16-2008, 10:33 AM
bump it
