Help with Hissing sound
Old 06-14-2008, 08:12 AM
5301113's Avatar
Question Help with Hissing sound
I have a hissing sound that i cant figure what is doing it.It's some where behide the TP or before the intake maybe one of those rubber pipes. The sound is always there. It just started last nite.Help me
Old 06-14-2008, 08:44 AM
AFASTYZFR1's Avatar
sounds like a vacuum leak
Old 06-14-2008, 08:59 AM
5301113's Avatar
I'm thinking the same thing but i cant find it
Old 06-14-2008, 09:01 AM
AFASTYZFR1's Avatar
I would tighten the intake some in the proper order which can be found on ls1howto.com, just to be sure....then look for and lines that are disconnected
hevymetalg's Avatar
Angry
is it like a whining sound cause my just started doing that too!
Old 06-14-2008, 09:16 AM
5301113's Avatar
no its hissing. It sounds like when air is coming out of a tire
Old 06-14-2008, 09:17 AM
5301113's Avatar
Nothing looks disconnected
Old 06-14-2008, 09:46 AM
hevymetalg's Avatar
Talking
get some carb cleaner and spray it around the manifold see if the engine dies out and that will be where you leak is
Old 06-14-2008, 09:50 AM
5301113's Avatar
OK after reading some posts.I hoping it's a ring seal or pcv rubber hose,egr ring seal.I'm hope it's not an intake leak
Old 06-14-2008, 10:59 AM
tording99Z28's Avatar
Are you throwing any Check engine lights? Check on the underside of the PCV hose where it connects to the intake. Mine opened up a crack right there from the heat and the angle of that rubber hose. Mine was also throwing lean condition codes for bank 1 and bank 2.
Old 06-14-2008, 01:06 PM
5301113's Avatar
No codes yet but i do need to check the PCV hose
Old 06-14-2008, 03:50 PM
5301113's Avatar
FOUND A CRACK ON THE PCV HOSE .I dont know what size it is to replace it
It the hose from the tp to the pcv , two inches long
Old 06-14-2008, 04:57 PM
AFASTYZFR1's Avatar
i think it is 3/8"
Old 06-15-2008, 10:03 AM
5301113's Avatar
thanks i will order it from gm
Old 06-15-2008, 04:49 PM
I just went and got myself a piece of 3/8" vacuum hose and used some clamps and made my own 2" piece that goes there. I tried to order just that little piece but its part of the hole PCV tube assembly which is like $110 from the dealer. If you find just that little piece for sale somewhere let me know please.
Old 06-16-2008, 11:01 AM
5301113's Avatar
Ok let me check in to it
Old 06-16-2008, 01:30 PM
ae13291's Avatar
i would also recommend changing the egr pipe seal! i dont think mine was leaking but when i took it out it looked all melted and screwed up! and its only like 5 bucks from GM
Old 06-16-2008, 03:25 PM
5301113's Avatar
Is that the little two inches hose before the PCV? It connects to the intake.
Old 06-16-2008, 03:43 PM
Chadlee2KZ's Avatar
Just did mine yesterday. SES light went off within 25 miles. Sounded cool while it was doing it like a baby turbo...
Old 06-16-2008, 03:45 PM
ae13291's Avatar
nope its the hose on top of the intake right after the throttle body! unless u removed ur factory egr system!
