opinions on my tune please.Sts gt67 Trans am.
Hey I am running an Sts kit with the 67mm turbo. I have am running an ls6 intake, Cat delete kit,racetronix 42's and fuel pump.I think the #'s i have in the Ifr table are a bit big. The ltft's are high. I think they are compensating for it. I would like some opinions please.
Thanks,Chris. Hptuners is what i was using and have the wideband as the aem one. volts x2+10.
I can email you the tune and logs
It's almost entirely stock! The only reason it's not LEAN-lean at WOT is that you have + LTFTs locked at like 8% and 10% on the two banks. Stock MAF table, stock VE table, all stock fueling tables, even PE...
Timing *looks* really low at 13 deg, but you didn't mention an IC or meth, so maybe it needs to be that high because of your IATs.. Not much info in your description really. Your IATs rose 53-55 degs F during those 3 gears pulled, which would be unacceptable for anything I owned and would impress the same the owner of any car that I had to tune like that. You have strong visible knock during WOT which is also absolutely unacceptable on that stock (again, a guess because there is little description) bottom end, and can end up costing you a piston or more.
I would address the high IATs before I did any more tuning or "hard pulls". You need an intercooler or meth, or better yet both. If you are running under 7psi, calibrate the MAF so that you arrive at commanded fueling. If you are running any more than 7psi, I would go to the 2-bar OS so that you don't have to cheat fuel into PE which can add some serious weather dependencies and is not boost-based at all.
Good luck with the setup.
^^It is all mostly stock I don't know what to change. Not sure on how to calibrate the maf the histogram I have doesn't work with the 98 pcm.Basicly the ifr table and the timing maps. I am installing a water meth kit today And still need some more piping to put the twin intercooler ati set up on. There are not really any good shops I can take my car to here for tuning. The closest one is a couple hrs away. How much would you charge for a tune. Thanks,C
I am up in Calgary Alberta Canda. I just don't want to blow this up. Should I change my ifr table. I think i should reduce the size of the ifr #'s to get the fuel trims back in check before I mess with the pe or maf table. I think all the part throttle stuff and cruise should be the same as it was before. Or am I wrong in this. What size nozzle should I use for the water meth and I assume I should lean out the pe a bit while spraying.Thanks for any advice.
Ciao.C
Ciao.C
do not fiddle with the IFRs
get them correct for your injectors and leave it alone
take your PE table and richen it up, take all of your spark table (high and low) and make them 16 degrees at the top end.
take your OL commanded fueling table and lean it out, so that PE mode takes over it.
that will get you to a shop/place to get it tuned professionally
you seem to be getting near commanded fueling at WOT, so why are you commanding (and getting!) like 12.34:1 under boost? Shoot for about 11.5:1 for longevity. Your IATs look fine now. How much boost are you running? That knock is no good in the top gear, it's cylinder temperature rising under boost. Fixing your AFR will get you back into safe territory. Unless your boost is some ragged edge level, I'm sure that you will be able to run more timing as well once the fueling is fixed.
The boost is a.5 bar spring, it spikes to just over 9 and settles at around 7 psi. I have a boost controler on the back with about 5 feet of hose on it so I don't have to crawl under the back to adjust it. To compensate for the intercoolers and piping. I think I am going to take it off and see what it does, it is set in the all the way loose seting as it is. What do you think of the flutter on the maf? Could this extra hose cause the flutter on the wategate? Or is it kinda normal and it is just the way the wastgate modulates the air flow?
Like I said I am going to try the short piece of hose to the wastgate and hope that fixes the maf dance.
