Homemade blowdown tube
Old 06-15-2008, 03:19 AM
jetlag's Avatar
Default Homemade blowdown tube
I have about 20ft of 5/16" aluminum tubing....If I wanted to make a blowdown tube using this....How would I go about attaching it to the bottle?
Flare the end of it? specific fitting?
Old 06-15-2008, 09:16 AM
Ping King's Avatar
LS1Tech 20 Year Member
5/16 is way too small to properly vent a bottle.
Old 06-15-2008, 12:29 PM
99DWPTA's Avatar
Blown down tubes are helle cheap why would you waste your time
Old 06-15-2008, 03:17 PM
Robert56's Avatar
You prob mean 5/8 tubing? Yes, sure you can make your own, oppropriate end fitting and flairing of the tube is you need. Remember though, to be NHRA legal it has to vent out side the vehicle if in the passenger compartment. You could also use braided line and AN fittings if you like and that will be easier to route out side.
Robert
Old 06-15-2008, 03:26 PM
jetlag's Avatar
Oh dang, that's right..5/8..oops.
Old 06-15-2008, 03:28 PM
89LS1RS's Avatar
Default hmm...braided hose
what size hose do you think it would have to be to be legal? -8
i havent got around to getting a blowdown tube yet, and any stock one wont make it to where i want it to go, so i was thinking of making my own so its all one peice and routed how i want, but if you can use hose then it would make it even easier...
Old 06-16-2008, 04:39 AM
jmill96Z's Avatar
-8 will work perfectly. Just make sure you have a -8 fitting on your bottle, and hook up a bulkhead fitting to your vent point.
Old 06-16-2008, 01:42 PM
89LS1RS's Avatar
thanks jetlag
Old 06-16-2008, 02:55 PM
jetlag's Avatar
Originally Posted by 89LS1RS
thanks jetlag
I didn't do anything??
Old 06-17-2008, 12:47 AM
Robert56's Avatar
here's what i did with dual blow downs, home made with parts from speed shop. It's a "T" bulk head fitting that goes through the tire well, but you can get the idea and can make hoses to fit what ever route/lenght you like.
Robert
Old 06-17-2008, 09:36 AM
89LS1RS's Avatar
oops, i meant thanks to jmill96z, and now to robert56, but thanks to jetlag for starting this thread
Old 06-17-2008, 10:03 AM
Chris@NitroDaves
Guest
Posts: n/a
I know it'snot homemade but we do offer a universal BlowDown Tube
http://www.nitrousoutlet.com/catalog...roduct_id=1116
Just to give you an idea of how we have done it.
-Chris
Old 06-17-2008, 12:51 PM
LS1TECH Sponsor
DynotuneN2O's Avatar
Here is our universal blowdown kit - everything you need including the blow down fitting, burst disk, braided line and threaded end to securely mount in your trunk - $39
http://www.dynotunenitrous.com/store...p?idproduct=86
Dean
Old 06-17-2008, 09:08 PM
89LS1RS's Avatar
ok, 32.95 for 6ft -8
27.95 for 180* endura fitting
15.88 for 90* endura bulkhead
8.50 for straight endura hose end
85. 28 total, and thats getting the better endura fittings and 6 feet of hose
Thank you summit....duh
Quick Reply: Homemade blowdown tube
