FS: 1996 Z28 Camaro STS Turbocharged
FS: 1996 Z28 Camaro STS Turbocharged 400+rwhp $7200 OBO
This is a 1996 6 speed Z28 Camaro that has an STS Turbo installed on it. It has 132000 original miles. The car is garage kept. It has some minor scratches on the front end (local body shop says $250 to fix). Good car to boost because it has a cast iron block so you will not have to worry about it cracking up. Mechanically everything is good. Car is sold as is! (the pictures show a fiberglass hood, but now the stock hood is back on and the exhaust pipe is no longer there, it is just a down pipe off the turbo)
The car has:
~STS Turbo kit
~5 PSI and 7 PSI springs
~15x3.5 draglights (Mickey Thompson) (I have the stock rims)
~15x8 draglights (BFGoodwrench Radial TA 28")
~Zoom Clutch (about 1000 miles on it)
~Tremec Transmission (about 5000 miles on it)
~Tial BOV
~Nelson Tune
~C2 Boost Gauge
~C2 Wideband AirFuel Gauge
~Fuel Pump
~42 lb fuel injectors
~52 mm ported throtle body with an air foil powder coated red
~Granatelli MasAir Flow sensor
~160 degree thermostat
~Methanol injected
~Sub frame connectors
~UMI torque arm
~UMI lower control arms
~UMI panhard bar
~AGX adjustable shocks in the rear
~Alpine Head Unit
~35% window tint (3M=the best quality)
~aftermarket wing (I also have the stock wing)
Asking $7200 OBO
I can meet you within 50 miles of 21047...
i will post pics in a day or 2...
The car has:
~STS Turbo kit
~Tial BOV
~Nelson Tune
~C2 Boost Gauge
~Fuel Pump
~Methanol injected
~UMI torque arm
~UMI panhard bar
~Alpine Head Unit
Asking $7200 OBO
