Why a FPSS alone will not help!!!! FREE LEAN SHUTDOWN SWITCH!!!!
LS1TECH Sponsor
All you need to be entered in the drawing is to post a link and picture of your favorite Dynotune Nitrous Product! The most popular item MAY become a future free giveaway!
Did you know that you can run lean, damage your motor and your fuel pressure can still be fine? You can have good pressure but not enough fuel volume your FPSS wont help. If you have a clogged or faulty fuel solenoid the FPSS won’t help. You have a clogged fuel jet the FPSS wont help.
Check out the features!
http://www.dynotunenitrous.com/store...p?idproduct=67
--Microprocessor controlled
--Built in Air/ fuel ratio display (narrow and wideband)
--Built in TPS (WOT) Switch
--Peak and Min A/F memory during the run
--Multiple outputs 12V and Ground
--Multiple Trigger inputs 12V and ground
--Programmable trip points
--Adjustable delay to let lean spikes settle
--6 Foot wire harness Light Weight
--12 Volt Operation
--Fast response
--Super Low Current
--Draw Micro Package Mounts Anywhere 1.8" Wide x 2.4" Tall x .9" Deep
CONTEST ENDS JULY 18th!
Dean
--12 Volt Operation
--Fast response
--Super Low Current
Dean
You can always use a wideband for tuning and saftey.
http://www.dynotunenitrous.com/store...?idproduct=210
this is my favorite product by far!!!!!!!!!!!!!!!!!
Why get out of the car to turn your bottle on.....
http://www.dynotunenitrous.com/store...p?idproduct=16
Everything From DynoTune Rocks!!!
Awesome gauges!
http://www.dynotunenitrous.com/store...p?idproduct=19
http://www.dynotunenitrous.com/store...p?idproduct=21
But I have to say the killer bottle brackets are my favorite!!! Can't forget the great bottle warmers too.
http://www.dynotunenitrous.com/store...p?idproduct=17
http://www.dynotunenitrous.com/store...p?idproduct=54
Dual XD-16's, from DynoTune of course.....
