Engine Stops While Driving???
Today my cars engine stopped when I slow down.. it has automatic transmission.. Sometimes when I start engine the idle goes down (battery gauge goes down too) and engine stops..
Any ideas???
Any ideas???
But today engine stops when I slow down my car.. after that happened I crank the engine and it starts.
You say it can be becuz of Battery or alternator, not about engine parts or fuel pump etc?
On the other hand, when a fuel filter is dirty the engine will first begin stalling when at idle and when coming to a stop. Thats when the fuel pressure is at its lowest and if there is a clog building up in the filter, thats when the clog will win the battle and the engine will stall. Under acceleration or while crusining the pressure is much higher and can defeat the clog until it gets really bad. Also, clogged fuel injectors.
When was the filter changed last?
I don't know what it is yet, could be alot of things, but when a voltage guage drops I first think of electrical stuff.
And you mean dying? my cars engine is dying? I hope not..
cuz it limited slip has been changed, transmission rebuilt.. and engine is dying it cost me much hope not happen soon..
I hope its only clog and filter..
By the way thank you for your interest!!
I really donot remember when, may be 2-3 year its same.. I used Wynns injector cleaner add it before adding fuel.. it happened 1 time again after I do that.
MAF could be dirty too?
Change the fuel filter, its a very cheap and fast job to do. It will rule out the filter anyway.
I think I got problem!
My cars at idle or at D(while stopping) it show between redline and 20psi..
Why that can be happen??
Car donot go tight.. I am not sure what is happenin.. :/
