OFI guys...how did you run plug wires?
Old 06-21-2008, 06:59 PM
theblur98ss's Avatar
Default OFI guys...how did you run plug wires?
I've seen a few posts where guys had to zip tie their plug wires. I'm running 10.4mm wires on a relocation kit and with the longer straight boots I'm getting header contact on every wire. Did anyone change out to 90 or 45* boots?
Old 06-21-2008, 10:13 PM
DanZ28's Avatar
Are you running your wires under the headers?
I'm planning on running 90* boots on mine and going under the headers, don't know where I will put the coils yet, but won't be on valve covers.
BTW, I bought that SLP shortened spark plug socket and it worked great.
Old 06-22-2008, 06:37 AM
cablebandit's Avatar
i use the msd wires...bend the boots to about 70 degrees (afraid ill break them if i bend them more) and zip tie to coil pack brackets. I really need a wire with a 90 as it clears the plug
Old 06-22-2008, 10:41 AM
Hennytime's Avatar
like these?
LS2 corvette plug wires are bent off the plug
Old 06-22-2008, 12:35 PM
man those taylors look like just the ticket. I think you have to get a certain one to get them with the bends like those
Old 06-22-2008, 12:59 PM
How hard is it to cut off the straight boots and put 90's on? Do I need special tools? Could I just goto the auto parts and get the stuff. Not sure since my wires are 10.4mm.
Quick Reply: OFI guys...how did you run plug wires?
