bought a roller with a moser 9in question on brakes
its setup for drag brakes and i want to drive this car on the street from time to time i took some pics, but do you think i could swap my 10bolt backing plates on it and be good?
i got the best pics i could since the rear is still under the roller on jackstands
well hell if they'll be fine i wont mess with them
just thought since the disc was as thin as my gsxr i couldnt expect the brakes to be very good on the street
question next how fo you bleed that caliper since theres 2 bleeders up top and 2 on bottom, is it one per piston?
Those are some badass brakes, the reason for the 4 bleeders is, its a 4 piston caliper, just bleed them like any brake system, they make a one person brake bleeding kit you can buy at any parts house, i've heard they work very well, just bleed the furthest caliper first (RR), then LR ,RF ,LF being last (making sure you don't run the MC dry of fluid), just bleed one bleed at a time on each caliper, those rotors don't look too thin, your going to be surprized how fast that **** will stop, forget stopping on a dime with 9 cents change, more like 999999.9 with them bad boyz LOL.
