**f/s 2002 Seadoo Gti Le W/ Custom Paint Jom L@@k**
I HAVE A 2002 SEADO GTI LE 3-SEATER FOR SALE JUST HAD IT CUSTOM PAINTED WITH NEW SEAT FABRIC COMES WITH TRAILOR. HAVE ABOUT 1500 INVESTED IN THE PAINT AND SEATS. REASON FOR SELLING IS I HAVE MOUNTING BILLS I NEED TO GET PAID OFF. ALL MAINTNACE RECORDS KEPT MEANING WINTERIZING AND DE-WINTERIZING ETC.. JUST PUT A NEW GEL BATTERY IN THIS YEAR ALSO. ASKING PRICE IS $5000.00
HERE ARE SOME SPECS.
The luxury edition of the Sea-Doo GTI™, the Sea-Doo GTI™ LE was designed to tow in style, with a touch of attitude.The GTI LE comes standard with a fold-down reboarding step, footwell carpets, dual mirrors, ski-eye for towropes and a speedometer - everything you need for a day of ripping it up on the water.
Designed with a modified version of the award-winning RX hull, the GTI LE seats three comfortably and for spotter comfort, it comes standard with handgrips and foot rests.
The Sea-Doo exclusive left-side forward/neutral/reverse lever is also standard and aids in picking up wakeboarders and skiers. Plus, the new revolutionary Sea-Doo O.P.A.S.™(Off-Power Assisted Steering) system provides additional maneuverability.
Engine Two-stroke, Twin Cylinder Rotax™
Displacement 718cc
Bore x Stroke 82mm x 68mm
Compression Ratio 6.2:1
Carburetion (1) Mikuni BN 40-38
Ignition Digital CDI
Transmission Direct drive with forward/neutral/reverse
Pump Axial flow, single stage, large hub
Impeller Stainless steel
Propulsion System Bombardier Formula water jet pump
Intake Rotary Valve
Lubrication Variable Rate Oil Injection (VROI)
Battery 12 volt
Starter Electric
Horsepower 85hp
Height 41"
Length 121.0"
Width 47.3"
Dry Weight 600 lbs.
Seating 1, 2, or 3
Oil Capacity 1.6 gal.
Fuel Capacity 15.0 gal. (Includes 3.0 gal. reserve)
Hull Material Semi-V with active handling geometry, fiberglass reinforced
Hull Type Modified Vee
Storage 33.8 gal.
[IMG]http://i179.photobucket.com/albums/w312/rossi692000/DSCF0322.jpg
[/IMG]
Displacement 718cc
Intake Rotary Valve
Battery 12 volt
Starter Electric
Horsepower 85hp
Height 41"
Length 121.0"
Width 47.3"
Dry Weight 600 lbs.
Seating 1, 2, or 3
Storage 33.8 gal.
[/IMG]
