Heater hose mod
Old 06-26-2008, 07:42 PM
vtirocz's Avatar
Default Heater hose mod
I need to drop the drivers side rear by 3/4", so was planning to do the heater hose mod to that side only. What's a good durable hose to get? Just regular 5/16" heater hose from Autozone, or is there something more durable? I only want to drop that corner by 3/4" and no more.
I'd appreciate any input.
Thanks.
Old 06-26-2008, 07:50 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Heater Hose. Same type that is connected to your heater in the car..Black/strong/durable/cheap. Home Depot will be cheapest.
Old 06-26-2008, 07:54 PM
wtomlinson's Avatar
what on earth is the heater hose mod
Old 06-26-2008, 10:40 PM
Pontiacerator
RevGTO's Avatar
LS1Tech 20 Year Member
It's 5/8 heater hose, not 5/16. The mod involves removing the upper spring isolators in the rear and winding heater hose over the coil on top.
Old 06-26-2008, 10:53 PM
NHRAMAN's Avatar
Exclamation
It will lower your vehicle 1/2-3/4 inch or so...
Old 06-27-2008, 05:46 PM
wtomlinson's Avatar
so it's a cheap way to get a little lower?
Old 06-27-2008, 09:37 PM
BREWS02WS6's Avatar
Yeah and you actually can tell a difference. Wish I woulda done it a couple years ago when I bought the car! Very simple to do, and I suck at car stuff.
Old 06-27-2008, 09:40 PM
wtomlinson's Avatar
does it just work for the rear or front as well?
Old 06-28-2008, 11:05 AM
vtirocz's Avatar
just the rear.
Old 06-28-2008, 03:03 PM
FireSilverLullaby's Avatar
Theirs a link to a guide in my sig
Old 06-28-2008, 10:37 PM
twitchtwice's Avatar
the only thing i dont understand about it is the fact that it will make your rear a little lower than the front.
Old 06-28-2008, 11:14 PM
Foxxtron's Avatar
Yes it will. Lowering the front will involve either installing a lowering spring or utilising a lowering spring perch (e.g. "coil-over" or Koni SA lower spring perch).
This thread (sticky) mentions the "Koni SA lower perch and rear heater hose mod.":
https://ls1tech.com/forums/suspension-brakes/842240-fbody-street-suspension-setup-review.html
Old 06-29-2008, 01:13 PM
BREWS02WS6's Avatar
Its not very noticable of a difference. I forgot the measurments I took when I did it, but its nothing to worry about (at least in my situation). Plus, when you do the whole spring/shock swap it wont matter anymore.
Old 07-02-2008, 10:14 PM
vtirocz's Avatar
Just bought 2ft of 5/8" heater hose from Advance Auto. Brand is "Thermoid" and it is rated to 62psi. ID is 5/8" and OD is 15/16" with polyester reinforcement.
Is there any other hose that is more "heavy duty" than this for the heater hose mod??? I believe Sam Strano recommended fuel hose in another thread, which looks more robust, but that only comes in 1/2" and smaller.
Any input is appreciated.
Thanks.
Old 07-02-2008, 10:23 PM
Pontiacerator
RevGTO's Avatar
You'll be fine with what you have. This doesn't require some super heavy duty type hose. Just put it on and forget about it for 3-4 years. Then you can pull a spring out and inspect it if you want.
Old 07-10-2008, 10:54 AM
vtirocz's Avatar
I tried 5/8" ID heater hose for this mod and the ID of the hose is much bigger than the OD of the spring when I put it on. I was expecting it to be a tight fit. Hopefull it holds up ok.
I may try using some 1/2" ID hydraullic hose rated at 200psi..
Old 07-17-2008, 07:12 PM
Dan
Dan's Avatar
You took the words out of my mouth.I just did the mod myself 10 minutes ago..It looks good..I was disappointed the back didn't drop more when I lowered my car 2 weeks ago. Then i was talking to someone & he asked if I did the hose Mod. That did the trick This is on my 98, not the car in the sig
Old 07-17-2008, 09:33 PM
yeah i just used heater hose from when i took off my A.I.R. system and it held up fine.
Old 07-17-2008, 10:56 PM
Pro52R's Avatar
Wow...
Common sense has went away over the years..
Heaterhose....i guess that is a word for any other hose, besides the one you say?
Old 08-21-2008, 07:42 PM
30th ponyslayer's Avatar
is it ok to do the heater hose mod to the drivers side only,,,,just put strano springs and kyb agx shocks but my drivers side rear stayed a full inch higher than passenger side which is how it was before springs so i didnt expect any different..last night i pulled the driver rear spring and did the hose mod ,,worked great and took my 1 inch difference down to 3/8...looks soooooooo much better now,,but is it ok mechanically to do this
Quick Reply: Heater hose mod
