The rear of the oil pan bolts
Old 06-28-2008, 06:34 PM
02' hawk's Avatar
Default The rear of the oil pan bolts
The long oil pan bolt has managed to strip out. What can i do to get that long bolt tight without removing the oil pan? (the 2 in the rear)
Old 06-29-2008, 06:58 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Take the transmission out and tighten them from the back side
Old 06-29-2008, 04:51 PM
02' hawk's Avatar
NO! I am refering to the 2 long bolts that you can see on the bottom of the oil pan in the rear. One of them is stripped out and i can't get to the threads to re-tap the threads.
Old 06-29-2008, 08:49 PM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
temporary fix---teflon tape on the bolt. and close youe eyes and hope it works
but the right way is to............well you know!
Old 06-30-2008, 07:28 AM
02' hawk's Avatar
Thanks. I even thought of a little bigger size bolt to put in there with a courser thread.
Old 06-30-2008, 08:47 AM
red83's Avatar
dont put a bigger bolt in it w/o drilling and tapping. it will bust your block. especially if its alum. just put a couple of rounds of teflon tape and get it snug. im talking snug as in a nut driver. not a ratchet
Old 06-30-2008, 10:50 AM
Z'mnypit's Avatar
Its not in the block, those two long bolts are in the rear cover.
Old 06-30-2008, 11:13 AM
02' hawk's Avatar
Rear cover?
Old 06-30-2008, 12:10 PM
Z'mnypit's Avatar
Originally Posted by 02' hawk
Rear cover?
Yes, just like the front timing cover but this one is on the rear of the block behind the flexplate/flywheel. Those two long bolts you are talking about thread into that cover and not the block
Old 06-30-2008, 12:42 PM
Randy WS6's Avatar
Yes, its the rear cover that has the rear seal in it. You can Take a old 1/4" drive extension and weld the tap to it to reach, Ive don't it and it works,But some extension are thicker than others, Or weld a 1/4" rod and weld a (T) at the end for a handle. I would try this before removing the oil pan
Old 06-30-2008, 12:44 PM
brad8266's Avatar
You are only suppsoed to tighten those 2 bolts to 9 ft-lbs (basically hand tight) So be careful next time. Yank the tranny and buy a used rear cover in the parts forum.
Old 06-30-2008, 01:17 PM
02' hawk's Avatar
Smile
Thanks for all the advice guys! I never knew there was a rear cover!!
The ls1 is denfently A-LOT more modern than the older engines!
Old 06-30-2008, 03:03 PM
red83's Avatar
i was thinking *** backwards. i was thinking of the oil pan bolt to block bolts not the rear cover bolts. sorry.
i just replaced my pan (after a significant wheel stand). and yes the oil pan to rear cover bolts are 9 inch lbs.
Old 07-01-2008, 12:16 PM
02' hawk's Avatar
That's great to here! I'm getting there (i only came about 6 inches off the ground friday night and still spinning some. If i bust the pan open from a wheel stand then i think i will have an excuse to replace the rear cover.
Old 07-01-2008, 01:56 PM
red83's Avatar
thanks,
well to replace the rear cover you have to take the engine out. or completetly take the trans. out. you can tap it w/ it in the car easily.
Old 07-01-2008, 04:06 PM
brad8266's Avatar
thanks,
If you can get a tap and rethread it that is the simplest way to go, although it only takes an hour or so to pull the trans and get the rear cover off. Your choice.
Quick Reply: The rear of the oil pan bolts
