Stereo & Electronics - Ground locations
Ryan'sSS
06-28-2008, 08:10 PM
I need a little help finding all of the body ground locations.
My car cuts out when I'm launching and it actually hooks.
BigBlockCamaro
06-29-2008, 12:28 AM
Car cuts out in as in the Stereo? Or the actually car?
Ryan'sSS
06-29-2008, 01:20 AM
The car stalls and the clock resets on the radio.
Richiec77
06-29-2008, 06:17 AM
Is the battery mounted in the hatch or still in the front?
I'm not sure if anyone here know's all the ground locations, but we could probably help to figure out where to start looking 1st.
Ryan'sSS
06-29-2008, 04:51 PM
Battery is in the stock location using factory mounts (no movement) and the cables are in good condition.
The motor has been rebuilt in the last year and its been acting up since then. So my guess would be that one has something to do with the other. Thats why Im thinking it has something to do with a body ground.
Ryan'sSS
07-01-2008, 10:11 PM
Well this has been helpful.
blackbyrd
07-03-2008, 12:38 PM
there's 2 on the core support one on each fender one on the back of the passenger side head, there is a ground strap on the driver side of the block if im not mistaken been a while, these are all under the hood
inside there are 2 big ones under the dash on each side right next to the doors if you remove the kick panels you should see them, there is a small one under the center console, i think there was one under the back seats and there are a few in the trunk, hope that helps
glenb1991
07-06-2008, 10:23 PM
the main one for all my wires is the one on the headlight panel. mine was loose and caused my headlights to short out. chances are, if it was rebuilt, they moved the wires a lil bit so they may not all be sent to stock ground locations,
Richiec77
07-07-2008, 11:23 AM
Make sure to check the ground that goes from the chassis to the head. That is a very easy one to miss and can cause ignition problems.
fast01z28
07-07-2008, 11:59 AM
theres a ground strap underneath on the drivers side, near the alternator.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
