How do you clean your wheels?
Old 06-30-2008, 07:08 AM
ravensfan's Avatar
Default How do you clean your wheels?
I have black ZR1's and there is nothing better looking than when they are clean...Im curious what products you all are using to clean your wheels? I am going to be removing them and cleaning the entire wheel and want something that will not harm the finish but remove the brake debris.
Old 06-30-2008, 10:25 AM
ArcticZ28's Avatar
I believe they are painted so you would clean/care for them just like paint. You can clean them with a degreaser, then use a claybar and polish them/seal them to make them easier to clean in the future.
Old 06-30-2008, 10:30 AM
Bajapat's Avatar
you what ever cleaner you comforable with, I use meg wheel brightener, then seal with a good sealent
poorboys wheel sealent is what i use ..
after that it's just soap and water .. and a really nice brush to get deep in there
Old 06-30-2008, 10:33 AM
ArcticZ28's Avatar
Wheel brightener is pretty acidic stuff. Only use that when the less aggressive methods fail.
Old 07-01-2008, 06:48 PM
INMY01TA's Avatar
Soap and water.
Old 07-01-2008, 07:12 PM
Dimitri-'s Avatar
Does anyone know a good method for powdercoated + cleared wheels? Or are they the same?
Old 07-01-2008, 07:34 PM
Syclone354's Avatar
i use meguires spray wheel cleaner, scrub with a wash mit, then rinse off. works incredible and i use it on the silverado chrome wheels, the silver finish zr1s on the vette, etc. you just have to be absolutely sure you dont let it dry onto the wheels.
Old 07-02-2008, 01:10 AM
4150's Avatar
During a normal cleaning all I ever use is a sponge with soap(for automotive finish) and water and then rinse. If they are really nasty the harshest thing I'll ever use in diluted Simple Green in a spray bottle followed up with the previous method.
Old 07-02-2008, 02:43 AM
BayAreaSS's Avatar
I just put some car wash soap in a spray bottle with water. I then spray the wheels and wipe them dry with a microfiber
Old 07-02-2008, 08:37 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
An aluminum/mag wheel spray cleaner will work very well, just don't let it dry on the wheels. Soap and water will work fine, you and dimitri should also use a sealer after you clean them well. Then you'll only need to soap/water and rinse them (they will be much easier to clean in the future). I suggest a product called Rejex. Also the best wax IMO to use on your paint.
Wade
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 07-02-2008, 10:00 AM
Bajapat's Avatar
yep it is.. i normally cut it 50 50 with water but for really bad wheel you need 100%. but on a car your taking care of your self i see no need for it. as I said before soap and water should take care of it.
Old 07-02-2008, 10:31 AM
slt200mph's Avatar
soap & water
Old 07-02-2008, 12:06 PM
SIC LSX's Avatar
Originally Posted by slt200mph
soap & water
then i put wax on mine.
Old 07-02-2008, 01:35 PM
Jeep_junkie's Avatar
Soap, water, wash mitt. Sometimes Simple Green if they haven't been washed in a while
