Quick Help, Whats the Drill Bit and Tap size for a -10 Return?
http://store.summitracing.com/egnsea...115+4294906753
Depending on the NPT size of the -10 return fitting:
1/2-14 NPT TAP 45/64" bit Or 11/16
3/8-18 NPT TAP 37/64" bit Or 9/16
3/4-14 NPT TAP 59/64" bit Or 15/16
3/8-18 NPT 37/64"Bit
You should be able to use a 9/16 bit, they are easier to find...
Lowes should have it.
If not, try your local Fastenal.
Derek
Ended up being the
I was able to find a 1/8 tap. But the drill bit R was not there. I was told that a 21/64 is the same thing. Is this true?
http://www.engineersedge.com/drill_sizes.htm
Looks like a "R" bit is a .3390, closest down size is a 21/64" (.3281) or up size to a 11/32" (.3437)
I pulled that off my old machinist cheat guide, Im guessing that chart I posted is the same
BTW, go to any fastner supply (around here we have Automotive Fasnters) and they will surely have the "R" size bit you require, or you can order it from Grainger.
http://www.grainger.com/Grainger/items/1G683
You can use the 21/64" but its gonna make for a pretty tight tap and your gonna have to make sure and use liberal amount of cutting oil and back up alot cleaning out the threads.
Just like this:
http://www.acetoolonline.com/Product...rce=googlebase
Here is the bit you need:
http://www.buy.com/retail/product.as...45&dcaid=17902
a standard 9/16" bit will work...
Where did this type R bit come from???
Thats not what you need.
Derek
