Full Throttle Timing Tuner: Good or Junk?
I was recommended to use this by the company that I bought my N2O kit from. A local shop then told me that it's junk and the only way to safely adjust the timing for nitrous is to have the computer tuned. I'd like to have something adjustable since I'm not gonna be spraying the car all the time and I don't like the idea of losing a bunch of power from a nitrous tune 100% of the time. Does anyone have any experience, good or bad, with this or any other similar products?
Thanks
Thanks
I'm not quite sure how you would wire that up. Aren't these things armed when you arm the activation switch to the spray? Doesn't make a whole lot of sense to me.
Screamin, what size of shot are you going to run? If around 100-125, throw some TR6's in with some good gas and have fun. Unless your local shop put your tune on the ragged edge with timing you should be fine.
I was planning one running a 75 shot until I make sure everything is running well. The shop said I'd be fine with that or a 100 shot. I'm just assuming that the power is gonna be addictive (or I'll lose a close race, lol) and I'll be jetting it for a 150 shot before I know it. I definitely want to upgrade my fuel system before installing the kit. Maybe I'll call and ask the manufacturer if there's a way to make it work the other way around. If not then I'll probably just go with the tuner anyway. I haven't liked alot of the "advice" that this shop has given me (things like Dart heads make 0 hp, and stay away from heads because, in general, they aren't worth the money, and don't go with nitrous because you have to check spark plugs...and they know I'm a mechanic).
Anyone really know how much timing you can add with these timing tuners? I think you can keep cranking it up but you don't see any gain after like 7 degrees of Total WOT timing? Going by the laptop timing advance and watching the wideband anyway.
Is there something better out there, as I am running a mail order tune and would like to add more timing when I am on bottle.
I have used the timming tunner on many installs as well as sold tons of them. The timming tuner and the MSD timming twister are the only reliable electronic devices on the market that I would suggest using for timming controll. By using these devices you can run max NA timming and remove the timming when the nitrous is engauged.
Dave
Dave
Guest
Posts: n/a
Copy and pasted from another board.....
"By adding nitrous oxide to an engine, the total amount of oxygen is increased and other gasses that do not support combustion (mostly nitrogen) are decreased. This speeds the burn rate and requires less timing advance for peak output. It is hard for many people to grasp gaining power with less timing, but it’s a fact. Peak cylinder pressure must occur approximately 20 degrees ATDC to make peak power. If you speed the burn rate, peak cylinder pressure will occur to soon. It is easy to run too much ignition advance with nitrous, but too much will not only hurt power, it can quickly bring a nitrous engine into detonation and destroy it."
Hope this helps.
I have a Timing Tuner and you can set it up to pull or add timing for both N/A and nitrous. Two different settings. If I remember correctly, you can pull up to 8 degrees of timing with it. I'm switching to the HSW Interface, though.
Hope this helps.
Hope this helps.
