Any body putting a Ls1 into a 67-70 impala
Old 06-30-2008, 11:10 PM
68 impala's Avatar
Default Any body putting a Ls1 into a 67-70 impala
I am dropping in a 6.0 lq4/4l80 into my 68 convert. I have already switched over to the f-body oil pan and when i did the steering center lands right in the middle of the oil pan. The Lq4 oil pan hangs to low. And the problem is that on my 68 the steering component are behind the engine cradle. The center link neeeds to be 2 inches lower then everything would work fine. Thanks for any suggestions.
Old 07-01-2008, 11:07 AM
LS1TECH Sponsor
Carshopinc.com's Avatar
What are you using for mounts? The f body pan is one of the worst for rear stear conversions and will either need to be modified for the steering linkage clearance or you can purchase a after market pan such as this:
http://carshop.carshopinc.com/produc...d/81168/LS1PAN
Or you may try the lh8 pan....
Old 07-01-2008, 08:05 PM
68 impala's Avatar
I got the mounts from your shop about 3-4 months ago ($39.95). And the after market pans don't clear either. On the pan you have the sump would need to start further back. The 12 inch section would need to be 14"11/16 and the 9"11/16 inch sump section would need to be 7 inches. Thanks though
Old 07-02-2008, 03:55 PM
wave1957's Avatar
I have an LQ9 in my 70 Impala. It is a rear steer car. I am using TransDapt engine mount adapters. I use the LQ9 oil pan which had to be cut quite a bit, for 2 reasons: hitting the center link and hanging too low. I had the oil pick up tube modified too.
To maintain capacity, I made some sort of "wings" on each side of the pan (which required moving the oil filter): I now have about 7 quarts of oil in the pan.
Old 07-03-2008, 08:39 AM
68 impala's Avatar
Thanks for the info. I will look into that method! The only place that I was able to find that would modify a cast alum oil pan, only wanted to do an f-body pan. Everyone in Detroit acts as if they are scared of welding cast alum. Where do i find transdapt mounts?
Old 07-03-2008, 01:06 PM
68 impala's Avatar
I looked at the transdapt motor mounts. they are the same as the ones I got from cars inc.com
Old 07-03-2008, 05:31 PM
wave1957's Avatar
I guess any welding shop can weld an oil pan if they can weld aluminium, it does not have to be an auto shop. Mine was welded by a custom car shop and they did a shitty job!
To save money on the shop time, I bought sheet aluminium and cut all the pieces needed, brought the whole thing taped together and the shop only had to do the actual welding.
Old 07-04-2008, 11:00 PM
68 impala's Avatar
What headers or exhaust manifolds did you go with?
Old 07-04-2008, 11:01 PM
68 impala's Avatar
And pictures pictures pictures, you inspire me at this point
Old 07-05-2008, 10:45 AM
wave1957's Avatar
I have used 2ng Gen Camaro Big Block Hooker headers, welded on the LS1 header flange sold by GMPP. I did not do it myself, the same shop that did the oil pan did it for me, so I do not know the exact amount of work involved but the headers are quite close, they did not need to cut any pipe, for instance.
Only one primary pipe needed to be notched for a spark plug clearance. The same shop also welded bungs for the O2 sensors close to the end of the headers.
Plenty of space on the passenger side (I actually dropped the header on the floor), rather tight on the driver side.
By the way, make sure you put thread sealant on the header bolts because it seems on some LS engine heads, the bolt holes open into the water jackets. It is already annoying enough to start these bolts without having to do it twice!!
I would love to post some pictures but last I have tried to do it from my camera, LS1Tech told me my file was too big to even post one picture: so now, I do not know how to do it anymore (and no, I am not good with a computer...).
Old 07-06-2008, 11:46 PM
68 impala's Avatar
Thanks Bro you give me a lot of great ideas. If you can figure it out you can email to me, thomas6157@sbcglobal.net I would love to see what I am working toward. Thanks alot
Old 02-01-2015, 04:08 PM
wildmanaaron's Avatar
Could someone post some pictures of how they modified their oil pan to fit the rear steer configuration? I am contemplating an LS1 swap in a 1970 Impala Convertible.
Old 02-02-2015, 05:46 AM
kwhizz's Avatar
Heres a link to my 66 build..........Lot's of info
http://www.yenko.net/ubbthreads/ubbt...car#Post455453
Ken
Old 02-03-2015, 06:43 AM
alocker's Avatar
There have been a few 65-70 swaps and the Holley 302-1 pan seems to be the best because it has the shortest rear sump. Pretty sure that's the pan Kwhizz above is running along with Nicke and one other guy. Search Impala and you will see the build threads.
Old 02-06-2015, 09:19 PM
Thanks for the info. What about the GM Performance Parts oil pan Kit. I haven't compared the two dimensions yet to see how much of a difference there is.
Did anyone else have to add more to their motor mount adaptor plates to get the engine up more for clearance like I saw in KWHIZZ's build thread?
Old 09-14-2015, 02:28 PM
FishTaco's Avatar
I have a 70 Impala two door HT that is in the paint shop. Ride tech is installed, Big Wilwoods also.
Hopefully, I will be installing an LS this winter. I was thinking an LSX454 but have yet to finalize...
Quick Reply: Any body putting a Ls1 into a 67-70 impala
