PS pump failure? susspension problems?
so driving down the highway the other night a big rig tire exploded in front of me and i was unable to swerve due to traffic. im now having problems with my front suspension or Power steering pump possibly. i get a shuddering feeling when i turn my wheel when the fluid gets hot. it noticed the fluid looked kind of like cappichino did a flush and went for a test drive. after i did my damnedest to flush it i came back and it looks almost the same as before.
when im driving about 65 it seems to pull a little to the right(the side that took the brunt of the tire i think) but when i do hard stops from top of 1st it holds fairly strait.
thoughts? tips? suggestions?
1 Post
ur power steering system is sucking in air some how, check all the power steering lines, could also be the power steering pump too! and u have to check the entire front suspension for any bends or damages
yea ive check the front suspension the best i could on the ground, looked ok. my floor jack is busted till i can get a rebuild kit for it.
how would the PS system be sucking air? the lines are all under pressure so wouldn't it just spit out all the PS fluid at once?
1 Post
my friend had the same problem on his car, it was some releif valve o ring inside the `ps pump that made a bunch of air bubbles always in the reservoir. so u might have to get a new ps pump
