Nitrous Kit.... anything missing?
I am about to place my order for the following parts and would like to know if you see anything missing from my setup.
LS1 Stock 78mm EFI Plate System w/10lb Bottle
Automatic bottle heater
Purge Kit
Fuel pressure safety switch
Nitrous filter
NHRA Blow off fitting
Blow down tube
Digital dual stage window switch with built in TPS activation and gear lock out feature
Nitrous Outlet '98-'02 F-Body Console Switch Panel w/Guage
860-F-Body Bottle Mounting Bracket
NGK TR6 Plugs
Anything missing?
Oh and does the digital dual stage window switch allow you to control rpm activation and deactivation? If not what would I need?
Purge Kit
Nitrous filter
Blow down tube
NGK TR6 Plugs
Anything missing?
