new d1sc build
Old 07-05-2008, 10:41 AM
ZDOG's Avatar
Default new d1sc build
well do to a bad score on a leakdown test(#7 was 35%) i have pulled the stock 17000 mile engine and tore it down. indeed # 7 was missing half a ringland at 8 psi.
after a few colorful words i decided to say screw it and do a new long block. im having LME build a stock displacement ls2. im reusing most my covers and crank. im going with : stock crank
manley rods
wiesco blower pistons
stainless chrome rings
ls7 lifters
melling oil pump
double roller timing chain
stock/cleaned 317 heads with patriot performance extreme spring kit
arp head bolts
trickflow pushrods
cam is down to 2 choices ill pick soon enough
9.5.1 compression
also picked up a text oz700 to go in.
this was my first time pulling a motor and tearing it down. i took it out the top and thought it was pretty easy to do,even in my tiny garage. the hardest part was the poly motor mounts!!! i still got some misc. stuff to pick up, you know the stuff that isnt that expensive but when your done is over a grand???
ill be doing the full install and new era will be doing the tune.
a ? for you procharger gurus.... if i had 8 psi on the stocker with a 4.5 d1sc pulley---what pulley do you think ill need to get 10-12 psi on a 365 with 317 heads?
just thought id share, no one i know really understands my obsession with tweaking and modifing cars. ill try to follow up with pics, i just hate resizing them!!!!
Old 07-05-2008, 11:27 AM
Jake@EPP's Avatar
manley rods
ls7 lifters
melling oil pump
arp head bolts
trickflow pushrods
9.5.1 compression
Try a 3.90 or 3.70 for that kind of boost. What kind of hp are you looking to make is the better questions, psi means nothing but restriction.
The 3.90 or even 4.13 will put you a little bit over 600 with stock heads.
Old 07-05-2008, 01:41 PM
ZDOG's Avatar
im shooting for around 600-650 rwhp. i want to limit my psi to under 11 though just because i have the ati 4.5 twins and im not ready to cut the front to go fmi.
jake.... in your opinion out of these to cams which do you like better and why......
222/228 575 575 114 or
222/230 566 573 115+2
thanks
ps. do you stock those pullies? and when changing the pulley whats the safest way to lock the shaft so it doesnt spin?
Old 07-05-2008, 02:22 PM
Jake@EPP's Avatar
thanks
Well if you have the twins, then you will need more of a efficent setup to make use of a certin impeller speed, the blowers will put out x amount of air at x rpm so depending on how fast will be somewhat on howmuch heat.
11 pounds should do about 625 or so. The twins are decent, but were not made for that amount of hp reliably. Your IAT's will tell the real story, i dont care what anyone says what there rated to.
We carry all pullies for the 8ribs and usualy have some 6 ribs. Honestly there isnt a way to lock it, use a impact gun to remove it, a belt wrench could lock it, but a impact is what ive used on every pulley swap. Use locktight as well.
As for the cam, bigger is USUALLY better, however ive seen some dang good combos. Are you dead set on those two cams? Ive seen a certin cam perform REALLY well on a stock headed motor, 226/230 600/600 113, hows 500rwhp on 4psi ?
Old 07-05-2008, 02:48 PM
ZDOG's Avatar
well the car is 99% a street car. thats one of the reasons i went with a procharger as itll stay out of boost unless i put the hammer down. the odds of this thing ever seeing more than 3 back to back runs....itll probally never happen. also im looking not to have to change springs as routine maintenance, hence the lower lifts. im not against meth as little insurance just not planning on it unless its needed.
its not adrag car and ill never cage it. so im looking for something fun on the street that the wife could drive whenever she wants. hows the drivability of your above mentioned cam? how is it on springs?
so to change the pulley just an impact? cool. its an 8 rib by the way. maybe ill just order a 4" from you and go from there?
thanks
Old 07-05-2008, 03:25 PM
Jake@EPP's Avatar
thanks
I wouldnt worry about the springs to be honest, run a set of patriot golds and your set. You will change the belt on the blower before you change the springs in comparision, some people have got well over 10k miles on a set of springs with a pretty agressive setup.
The drivability is great, it has plenty of off idle torque unlike larger cams. It also has a mild chop to it, so you can tell its cammed, but not too much. I liked the chop and the drivability, its easy to over cam a street car and many people do.
Old 07-05-2008, 03:41 PM
Tudds's Avatar
How many #s were you running to kill your motor?
Old 07-05-2008, 03:54 PM
ZDOG's Avatar
8psi.... lost 1/2 of number 7's ringland
Old 07-06-2008, 02:06 PM
BLNLS1/RX7's Avatar
Not that unusal.
Old 07-06-2008, 02:29 PM
ZDOG's Avatar
after a leakdown it it was exactly what i expected to find. what i didnt expect was an unharmed block.
Old 07-06-2008, 03:25 PM
Jake@EPP's Avatar
If you catch em in time you can have a good one, ive seen alot of both. Going bigger cubes is a advantage of a bad situation lol.
Old 07-07-2008, 03:51 PM
ZDOG's Avatar
to bad its a pain in the ***** to ship a block. to sell it is a bitch. i wouldnt mine learning to build a motor with it, i just dont have the room.
Old 07-29-2008, 07:43 PM
ZDOG's Avatar
well just a update: should be less than a month to get my long block. been killing time painting the undercarriage and accessories. im now running my gage wires and will hopefully have that done and the guages installed.
talked to bob and ordered a 3.88 pulley and larger air filter(hopefully i can shoe horn it in with the twin ic's)
man the little stuff sure does add up. clutch kit, lt1 radiator, pulley, belt ,air filter, 3 rounds worth of oil and filters, trans fluid, ported throttle body, wideband, o2 bung, 3 guages, 3 pillar pod, t stat, aluminum ic pipe, silicone couplers, t-bolts , specialty tools for those certain things, ect...ect... on top of 6+ g's on the motor.
im scared to add it up, i believe it be cheaper to just to do crack!!!
but in the end.... i just miss my car, i sure hope all goes well and i get some cruising in before the snow flies here and not take out the tranny or rear....at least not till next spring!
Old 07-30-2008, 04:36 AM
EPP
EPP's Avatar
Thanks, I appreciate it! Bob
Old 08-01-2008, 04:53 PM
ZDOG's Avatar
thanks for the fast shipping bob!
Old 08-19-2008, 08:21 PM
ZDOG's Avatar
just got the call today. should have the longblock in about 1 week!!!!!
Old 09-03-2008, 07:20 PM
ZDOG's Avatar
just an update. got the long block from ups today and dropped it right in. (i dont know about pulling and installing the motor from the bottom but i found the top to be easy as hell) other than battling poly motor mounts.!!!!!!
so the l-block is in / power steering pump is mounted and im now doing the grounds.
2 morrow hopefully ill have the clutch and tranny in , and if im real lucky the intake manifold.
snapped some shots of it while being installed, just need to resize to post.
Old 09-04-2008, 08:18 PM
ZDOG's Avatar
Default pics added
heres some of the block going in.
Attached Thumbnails new d1sc build-rsz_100_3995.jpg   new d1sc build-rsz_100_3996.jpg   new d1sc build-rsz_100_3997.jpg   new d1sc build-rsz_100_3998.jpg   new d1sc build-rsz_100_4004.jpg
Old 09-04-2008, 08:21 PM
ZDOG's Avatar
a couple more. yes one is just the mount bolt, that was the biggest bear. 25 minutes to get the motor in the cradle and a hour and a half to got that damn bolt in. its a victory shot i guess.
Attached Thumbnails new d1sc build-rsz_100_4005.jpg   new d1sc build-rsz_100_4007.jpg
Old 09-05-2008, 05:07 AM
EPP
EPP's Avatar
Looking good! Bob
Quick Reply: new d1sc build
