94-96 camaro gauge cluster in 93?
What would I need to put a gauge cluster out of a 94-96 Camaro Z28 into a 93 Camaro Z28? The only difference I know between the 2 are speedometers drives. The 93 being cable diven. What would it take to have it reading the right speed and where could I get it? Thanks.
No need as they are the same. 93's are different in some ways but not a completely different car. Check out speeddensity.org. There are several people that do the swap. It seems some people have to cut out the filter but some don't. I had to to get my tach from jumping everywhere.
I can't find anything on speeddensity.org. What would I have to do since I have 3.73 gears. My speedo is reading off. I know to correct it with the 93 cluster is to change the drive and driven gears in the trans.
