LT1 M6 Bolt-on guys with 4.11s come on in...
Old 07-06-2008, 03:11 PM
LM97Z's Avatar
Default LT1 M6 Bolt-on guys with 4.11s come on in...
& tell me what your ETs are, Now this is with STOCK cammed cars, just your basic bolt-ons, please list your 60fts, altitude & ETs with either a street tire or stickies, just trying to get a baseline on what i might run.
Old 07-06-2008, 05:27 PM
96LT1355Z28's Avatar
When I had just bolt on's I went 13.60 at 104 with a 2.2 60' on street tires and 140K miles. I had pulley, CAI, 4.10's, 6AL, 52mm TB, 1.6 RR, 160 thermostat, Hooker cat back, adj FPR, Hypertech power programmer, and centerforce clutch. Hope this helps.
Old 07-06-2008, 05:34 PM
CamaroRacing12's Avatar
auto guys speak up also.... im looking to go with 4.10's lol...
sorry for the thread hijack
Old 07-06-2008, 06:25 PM
camar0corey's Avatar
Best I've run.
60' 2.232
13.542@104.09mph
FL so I guess elevation is about nothing. Shitty street tires, Riken Raptors.
Old 07-06-2008, 06:45 PM
State69champ's Avatar
I have a buddy thats fullbolt on that runs 12.4s
Old 07-06-2008, 08:39 PM
3DFORMULA's Avatar
I see you have in changes, a Moser 9" w/4.11. You can then run slicks, which will knock that time right into the 12's.
Old 07-06-2008, 09:16 PM
LM97Z's Avatar
that would be great if i could see a 12.99, then again i wouldn't see why it wouldn't do it in the cooler months, i 'm also installing a good driveshaft for added insurance for sticky tires.
I did pull off a 13.7 on a 2.17 with 3.42s, i'm hopeing with the 4.11s & 1.8s or better 60fts, i should be there, that would be cool
Keep them coming.
Old 07-06-2008, 09:19 PM
30thanniversaryz's Avatar
In my 3.23 A4 on street tires, with just intake/exhaust, I could cut consistent 1.9s.
Old 07-06-2008, 11:06 PM
3DFORMULA's Avatar
Keep them coming.
I went 13.7 with my 3.42 also. For my 13.0, all I changed was:
Larger diameter cat-back, with straight-thru muffler(bullet style)
12bolt with 3.73 gears
26" slicks
That is the ONLY changes between those times and my best of the day, 13.09. Consistent 13.1's with the stock clutch. The clutch did NOT last all day tho'.
Old 07-06-2008, 11:26 PM
Purple95Z28's Avatar
13.30 @ 107.3 mph - 2.16 60', full exhaust, cold air, tune, 1.6 rockers, 4.10s on BFG gforce Sports (cheesy street tiresz)
Old 07-07-2008, 08:29 PM
96silverram's Avatar
I ran a 12.61 @ 109 with 26" ET street (Moser 12 bolt 4:11's) with pretty much every bolt-on you can do except, (NO PCM tune and NO cut-out). The car is a full weight WS6 LT1 with all factory options (I'm guessing the car weighed in the 3550 range when I ran that number). Since then, I have added ED Wright PCM tune and a bunch of suspension items. I'm sure the car has a 12.30/40 ish in it @ 110 plus.
Old 07-07-2008, 09:39 PM
firehawk238's Avatar
no offense, but if you really want a baseline, go to the track!
Old 07-07-2008, 11:26 PM
LM97Z's Avatar
Old 07-08-2008, 05:50 AM
BIG_T's Avatar
well im full bolt on's, suspension, and 1.6rr's
13.1@108
2.02 60ft (on a 275/40/17 street tire)
kcir (missouri)
im putting a moser 9in and have draglites with et street bias ply. ill get mid 12's easy.
Old 07-08-2008, 09:36 AM
LM97Z's Avatar
13.1@108
kcir (missouri)
Nice MPH, how are you getting that with a stock cam & just rockers? I can see 102-103, but 108, thats awsome , i'm in missouri too.
Old 07-08-2008, 10:23 AM
AChotrod's Avatar
I was running 12.8s at 108, 6spd, stock clutch, all the bolt ons and a 3.73 on drag radials w/stock cats.
Old 07-08-2008, 03:31 PM
BIG_T's Avatar
i have no idea man the car runs damn good for whats done to it. what part of Missouri u in?
Old 07-08-2008, 05:07 PM
LM97Z's Avatar
Branson, i'll be at Ozark Dragway this friday night to test it out, just got the 3rd. member & axles in, everythings nice & tight now, i'll pick up my driveshaft tomorrow.
Old 07-08-2008, 10:48 PM
3DFORMULA's Avatar
108 with just rockers is believeable. I'm at 106 with stock cam, stock rockers, stock exhaust manifolds.
Old 07-08-2008, 11:24 PM
LM97Z's Avatar
I'm at 1500ft. alt. with high humitity, i'll be lucky if i get 102 out of it (in good air), unless the 4.11s give it more MPH then the 3.42s, the only F bodies running faster then 106 (in stockish trim) around here are the LS1 cars, i know of a 95 bolt-on A4 running 13 teens, but his MPH is only 102-103 at best.
Quick Reply: LT1 M6 Bolt-on guys with 4.11s come on in...
