newb q's and a broken torque arm
ive had my car for about a year now. i drive it as a daily driver. when i bought it the car already had a 12 bolt and an edlebrock torque arm....
a few days ago i noticed some sounds coming out of the rear i lifted it and noticed the torque arm is broken where it gets bolted on
sorry if the pix suck but that is the best i could get at the moment
i tried googling info on the torque arm and thats when i noticed that this specific torque arm is for 10 bolts not 12.
so should i go with an adjustable arm?
i honestly dont know what kind of 12 bolt it is i just know its a 12 bolt, i cant find any logo or anything on it.
and also, is the 12 bolt (in general sincei dont know what kind i have) supposed to have a different drive shaft from the stock one?
Id recommend a BMR adjustable arm, that way you can get your pinion angle set exactly right. Since you currently have a 12 bolt in there, the non adjustable would be just a waist of money its preset for factory 10 bolt rear ends, the adjustable is the way to go. I would also be careful getting up on your car with a busted torque arm, its ok to drive it but just be careful, depending on what lower control arms you have you could through your rear end right out of your car. Good luck
We offer a few nice torque arm set-ups as well. We have adjustable torque arms starting at $299. We also have set-ups with built in drive shaft loops. Please take a look at the link below and let me know if you would have any questions. All the torque arms below will work on your 12-bolt... if your 12-Bolt has (4) small bolts, (2) on top and (2) on the bottom holding the torque arm in place it is a Moser brand.
http://www.umiperformance.com/produc...ategory_id=130
Thank you!
Ryan
Thank you!
Ryan
Thank you!
Ryan
Thank you!
Ryan
