07 Trailblazer SS Wet Kit Install
Just finished up installing a Hidden Wet Kit in a friends TBSS and figured I would share some pics. NX Wet kit w/ dynotune 1stage RPM/WOT switch, Harris Speedworks TB Plate and some other goodies bottle heater,blanket etc...
With Cover On you cannot see anything!
All solenoids mounted & wired up
Throttle Body Plate-Very nice piece!
Bottle mounted to rear compartment cover
Bottle Heater all wired in and on bottle.
Bottle blanket attached.
All switches are hidden in center console(Left to Right-Purge,Activation,Bottle Heater) Bag of Jets in bottom
Dynotune 1 stage RPM & WOT activation switch! Another nice Piece!
Thanks, I can't stand looking under a hood and seeing wiring nightmares and wiring thats not split-loomed. I prefer the OEM factory look. Every wire in the engine bay has been dressed with oem style split loom.
That is pretty bad ***. Now you need to get a remote bottle opener and stuff the bottle in the spare tire holder. If it would fit. Keep it all covert.
What jets are you starting off with, and what do wnat to be able to run? How much did all of hte nitrous stuff run you? Looks like 10lb bottle?
This was not on my vehicle so i'll let the owner chime in with what shot he will be running and his expectations. As far as bottle fitting in the compartment thats a negative. Thats where the amp is installed for the subs, I don't think it would fit in there even if the amp wasn't there anyway its pretty shallow. spare tire is underneath truck.
2004, body, disconnect, hidden, installation, kit, nitrous, plate, spare, ss, throttle, tire, traiblazer, trailblazer, wire
