Removing MAC midlength headers
I'm trying to drop these MAC midlength headers off of my car and I'm completely lost. I've tried jacking the engine a bit, removing the coil pack bracket, and every position possible without any luck on either side. Any suggestions, I'm going crazy here. Thanks
Last set I removed literally fell out. Some of the typical clearancing items for header installs are removal of the oil filter, removal of the pass side heat shields and disconnecting the steering shaft from the steering box.
i had to loosen up my motor mounts one side at a time and and then jack up the motor from the pan in order to get mine out. i guess not everyone has the same clearincing on there cars. i would say try that if you hadnt already.
