Question on a purge system
Hey, I have a 00' Trans Am w/ a NX 100 wet shot system. I bought a purge system w/ 2 outlets. I have the outlets coming out of the Ram Air in the hood (I have a cold air induction, so only the purge system is in the vents). When I purge, the nitrous comes out of the outlets but you cannot see it at all. I was wondering if the purge system is bad, or I'm I purging a small amount or could it be installed wrongly. I know it can be done b/c I have seen it work before. Thanks a lot, I appreciate it.
adam
adam
Re: Question on a purge system
The two nozzels are not coming out from the grill, they are behind it. And I did try and purge it for a longer amount of time and the bottle was at a good running temperature.
What was thre bottle pressure. You should be right around 1050. If the bpttle pressure is too low or close to empty you won't see anything, but you'll still hear it.
