ls1 carb question
Old 07-23-2008, 09:38 PM
81 Camaroman's Avatar
Default ls1 carb question
hi i am running a81 camaro with an ls1 g5x3 cam ported 241s EDELBROCK DUAL PLANE CARB MANIFOLD LOOKING FOR INFO ON WHAT SIZE AND TYPE YOU GUYS WOULD REC FOR ME THANKS
Old 07-23-2008, 09:48 PM
ten5nova's Avatar
I built a 5.3 with ported stock heads, 230 @.050 Lunati cam, and ran the Vic Jr. single plane manifold. I run a 750 Quick Fuel brand carb. Worked very well, on motor, and on the bottle. I would recomend the 650 or 750 Quick Fuel carb. Good luck.
Old 07-24-2008, 07:11 AM
SMAX's Avatar
What are the specs on that cam? Got any pictures of the car?
Old 07-24-2008, 07:24 AM
forcd ind's Avatar
a 750 is a pretty good all around size carb
Old 07-24-2008, 11:01 AM
LS1TECH Sponsor
Carshopinc.com's Avatar
quickfuel for the win!
http://quickfueltechnology.carshopin...1152/SS-780-VS
Old 07-24-2008, 09:14 PM
thanks for the info guys the cam is a 234/240 duration and .610/.608 lift
Old 08-01-2008, 03:01 PM
team39763's Avatar
Post up when you get it sorted out. Let us know how it worked for you. Get some video of it if you can.
Old 08-01-2008, 03:28 PM
Shawn MacAnanny's Avatar
holley 750 with vacuum secondaries. 72 primaries, 76 secondaries, and a 6.5PV.
