Reaching my 400rwhp goal
I just priced out all the stuff I am about to buy in a about 2 weeks
224R cam from texas speed
PRC Stage 1.0 ls6 cnc ported heads
LS2 timing chian
LS6 ported oil pump
42lb injectors
ud pully
3200 monster stall
dyno tune
3240.96
how close to 400 will this stuff get me along with stuff I already have in my sig
LS2 timing chian
LS6 ported oil pump
42lb injectors
ud pully
3200 monster stall
dyno tune
3240.96
well injectors really dont add power.. but at the same time they will.. with that combination you will be starving for fuel on the top end. so by putting 42 pound injectors you will eliminate that problem.. but refresh my memory.. whats the specs on that cam.. and whats the flow on those heads?
why not? right there your running better flowing heads(I think) than mine, with nearly the same cam, my numbers are in sig and thats with shorty headers and stock cats. Im getting LT's and high flow cats in a few days and should be running around 420rwhp. You should be pretty similar I would think
Also definetly have your heads milled to 59cc chambers, brought me up to about 11.1 CR.
i made 400+ with the cam in my sig. the 224 is not that big of a cam, plus the heads are no much better than stock.......
If it was me, get a little bit bigger of a cam.. Is your car a DD? While you have the heads off you might want to put in ls7 lifters
What made you choose the LS6 heads? From what I've seen, most people go with the ported 5.3 heads with that cam. I think you'll be able to make it, but honestly not much more through an auto. But who cares...autos are track stars, not dyno queens.
I would run some different heads. Those don't seem to do as well as the 5.3's. And also keep in mind that converter is going to suck up some power. Good for performance but bad for dyno #'s. But I think you will be close with what you posted up. The 224 cam isn't really known for putting up huge #'s but it does make for a very usable powerband so it should be fun. Good luck with your build.
