Stock 10bolt with 4.10s T-56???
mods listed below, do you think a brand new stock rearend with 410s will hold up with my t56 and mods listed below, i dont really wana spend the money on a beefy rearend right now.
sticky tire, 3500rpm launch can last 1 run or 100..definately no guarantees
https://ls1tech.com/forums/lt1-lt4-modifications/958408-drag-radial-stock-rear-4-10-a.html
Your passes with that motor on that rearend will definately be limited. I'd start saving some money up now for a good one. It really depends though. I'd be reluctant to put slicks on there. Drag radials might be you're best bet, but I wouldn't be launching it every chance I got even with those.
Mine made hundreds of passes with street tires. I put in new axles, studs, axle and carrier beaings, plus a diff cover and got 4 passes with slicks when the posi exploded! I had stock suspension except LCA's and the axle hop is likley what killed mine. It just depends on how hard your hitting/ shocking the tires and if any axle hop occurs as to how long it'll last. I'd start saving for a new rear just so you've got one less thing to worry about on the starting line!
?????????????????????????????????? Thats how long it will last with slicks OR D Radials, if your planning on buying a NEW rearend, i'm sure its going to cost your $$$$, unless you found one for next to nothing, if so, spend the money & get a moser 9" houseing/axle/bearing package, you'll be out a grand, then all you need is a 3rd. member, this you can pieced together with good **** for around 7-800.00, then throw some stickies on it & launch away!!! Thats my 2 cents lol, if my poor azz can do it, so can you.
I would go s60 or 12bolt. 9' is too big for a street car. That rear sucks up 20hp or better, between the added rotational mass and extra weight. I have watched my dad's 69 camaro run low 9's on a moser 12bolt, pulling a 1.26 60ft. The car was lifting the wheels high enough to see the whole exhaust under the car lol!
And to the OP, save you money for a rear end that you wont be worried about leaving you stranded on the side of the road if you put throttle to the floor.
I stand corrected, you guys are right. The s60 is heavier than the 9", I had the two mixed up. I still think the 12bolt is the route Im goin, or hopefully someday they come out with a 8.5 10bolt that will have the tq arm holes. The 9" is a good rear, but they compromise the ride of the car a lil bit. The 12bolt maintains a better ride. I'm just basing my opinion of a 9" f-body I rode in. It definately will hold up, but my car is really street only and I like to keep the ride quality as close to stock as possible.
