Pin A, C101 Connector
All of the threads in the Hybrids forum say that Pin A of the C101 connector (yellow/black) it's supposed to go to the Low Coolant Sensor. The diagrams from alldatadiy.com say that it's for the Vehicle Anti-Theft System Starter Enable Relay and is supposed to connect to the C220 connector and then to the BCM. I traced the wire and it does connect to the starter relay on the fuse box.
Any reason for the descrepancy or am I missing something?
It's a 68 camaro that's going to have the LS1 steering column and dash. I want to use the VATS so I'm trying to keep the BCM and all stock wiring as close to original as possible.
If the site was wrong, why would that same wire go to the starter relay?
